Hood hot to the touch?
Hi, new to the forum here.
I just purchased an '06 EX sedan AT. We are truly a Honda family now with an Odyssey, Civic, RL, and CL in the driveway as I type here. Anyway, my question is ... I drove the Civic a few miles, parked it, and came back 10 minutes later. The hood on the upper right and upper left about 10 inches below the window and just inside the seam is real hot (almost can't leave hand there). I felt the middle of the hood and it was barely warm. Can anyone tell me if this is common and what might cause so much heat in just two spots? What alarms me is if this gets this hot all the time, could this lead to premature paint failure there? Thanks for your help.
Acorns!
did it have anything to do with the heat outside.... sun reflecting off the windshield or something? I really woudln't be too concerned with the paint though. I know people who obviously leave their cars outside in year round heat, or temps of 100+ all summer long. Just keep the paint clean and you should be ok. I know my car at one point was outside in LA 24-7 and it was well over 100+ degrees for weeks on end in the summer.
With regard to civicwithnav's reply, I did consider that there might be something unique about the civic's exhaust system. It certainly appears that the engine compartment is very compact. I was not aware that the civic does without an exhaust manifold. Interesting ...
no exhaust manifold???
No exhaust manifold? can someone please tell me how that can be? I think someone is misinformed or is misinterpreting something as there HAS to be some type of exhaust manifold. As far as why the hood is hot...well, the engine runs at 200+ degrees (at least the coolant within) and the whole thing suffers from heat soak when the engine is stopped meaning the coolant stops circulating and the whole 300 pound mass of metal that makes up the engine and all accessories simply gets HOT until it cools naturally. Remember combustion temps can be over 900 degrees and the cat. is more than that so you might ask..what happens to all that heat? It fills the engine compartment and by default the hood and surrounding areas to include front fender tops.
| How to Prep a rusty chip for touch up? | dlux200sx | Detailing | 11 | 07-10-2006 02:12 PM |
| Hot Hood | Way2Short | Mechanical Problems & Technical Chat | 11 | 06-16-2006 02:25 PM |
| Fuse Taps - Always Hot / ACC Hot | disdigg | I.C.E., Electrical, Security, & Navigation | 4 | 05-07-2006 06:58 PM |
| How much to repaint hood | lordg | Garage | 0 | 04-23-2006 01:22 AM |
| Hot Wheels Wide Body kit | Ep3racer954 | Inside and Out | 6 | 02-04-2006 12:11 PM |
