#7 (permalink) | |
A Happy Man
I do remember this being talked about a couple months ago, so try a search . ( maybe "neutral rev limit" )might bring up what you're looking for . ![]()
2006 Silver Si |
#10 (permalink) |
dry revving, mentioned by si civic, is bad because the engine was designed to have load on it while climbing through the RPM's. On this car...even on the R18A, RPM's raise on a dime. I suggest you not look for a way to take this out because your car was designed not to do that. As for hard launches, they already peel out when you kick it up to 4500RPM as you drop the clutch.
#12 (permalink) | |
someone in the know...... thanks! |
#16 (permalink) |
I remember being at the dragstrip and was able to bypass the rev limit by slightly letting the cluthc pedal out a tad (little clutch slip). I do not reccomend this with a stock clutch. Made for a bad ass launch. I was in the 2.1's in the 60ft on all seasons.
The rev limit is activated by something in the clutch pedal(sensor) or possibly a speed sensor. More than likely the clutch pedal. |
#19 (permalink) |
I do look like a monkey
I can peel out fine bouncing off 5500. And I launch a little under 4k. And revving is bad in neutral? I would think it'll do damage if you're bouncing off the revlimter at 8000 for 10 minutes or something. But I doubt ANY damage will occur revving an engine for 5 minutes at 3,000 rpm. Especially when majority of honda service manuals tell you to rev the engine at 3,000k until the cooling fans come on to reach operating temperature when it usually takes even longer than 5 minutes.
#20 (permalink) | |
| 2006 check engine light and dont go over 3500 rpm | bodydraggin | Mechanical Problems & Technical Chat | 15 | 07-21-2008 08:48 PM |
| Break-in period and rev limiter? | adk | Bolt-Ons And All-Motor | 21 | 10-23-2007 03:06 AM |
| Civic EX 06 MT RPM Question | pkrovvidi | Civic Coupe And Sedan | 10 | 06-10-2006 01:19 PM |
| Rev Matching? | Silver8th | Garage | 39 | 06-09-2006 12:01 PM |
| Rev Limiter at 5500 | 06_civic_si_gi | Autocross & Sanctioned Drag Racing | 7 | 05-15-2006 09:56 PM |
