how strong are the SI trannys? - 8th Generation Honda Civic Forum
Old 08-04-2008, 03:22 PM   #1 (permalink)
k20fg2SI's Avatar
so i was dumb enough to go street racing im not a street racer..but i got asked to run a jetta and while pushin it i grinded 3rd made the nasty nosie and from 3rd i could not get into 4th at redline and now when Daily driving my gears all feel weird is there something wrong ?
k20fg2SI is offline
Old 08-04-2008, 03:22 PM   #2 (permalink)
B-Stylz's Avatar
'08 Si-R
Made for 197hp. Swap your tranny fluid.
B-Stylz is offline   Reply With Quote
Old 08-04-2008, 03:26 PM   #3 (permalink)
k20fg2SI's Avatar
i hope the bad grinidng i did didnt affect anyhting bad cuz i kinda missed shift too
k20fg2SI is offline   Reply With Quote
Old 08-04-2008, 03:29 PM   #4 (permalink)
SPOOLIN K20's Avatar
14.2@98 i/h/e
you might of tore out the syncos then your in for a bad day comming soon. . .now does it grind in every gear when shifting at low rpm?
SPOOLIN K20 is offline   Reply With Quote
Old 08-04-2008, 03:33 PM   #5 (permalink)
k20fg2SI's Avatar
no it just grinded the one time real bad but normal driving it fine it had a smell after i parked my car it doesnt grind all my girl get in smoothly now now like it was before so im wondering i did something bad for it to be so easy to get into gear
Old 08-04-2008, 03:34 PM   #6 (permalink)
14.2@98 i/h/e
smell was prob your clutch. . .did you at least win?
Old 08-04-2008, 03:37 PM   #7 (permalink)
k20fg2SI's Avatar
i won but i think i ****** my car up so it was a lose for me haha it was a 1.8T jetta turbo set at 8psi i hope nothing is wrong wit my tranny i still have warr but **** dealer gonna give me **** for it
Old 08-04-2008, 03:39 PM   #8 (permalink)
14.2@98 i/h/e
you should be fine if you happen to notice it doing it more and more you may wanna have it checked out but for now dont worry about it. . .as long as you didnt pull it while it was grinding yull be ok
i wouldnt worry about it
Old 08-04-2008, 03:42 PM   #9 (permalink)
k20fg2SI's Avatar
yea as soon as it grinded witha loud sound i pulled it out of 3rd real fast and then poped it into 4th but it could just be my clutch was fully engaged i hope im fine haha
Old 08-04-2008, 03:42 PM   #10 (permalink)
There are four keys to the right of the "M" key on the keyboard that want to introduce themselves to you. You should talk to them.
You definitely did something bad. You're in a civic, not a race car. I hope you had enough fun to make it worth replacing half of your powertrain that you undoubtedly damaged.
Itchytoe is offline   Reply With Quote
Old 08-04-2008, 04:00 PM   #11 (permalink)
k20fg2SI's Avatar
who knows
Old 08-04-2008, 04:02 PM   #12 (permalink)
nayilsi's Avatar
Originally Posted by DatBigDude View Post
Ibtl...
no no shut up
Old 08-04-2008, 04:25 PM   #13 (permalink)
Probably all in your head.
brzrkr626 is offline   Reply With Quote
Old 08-04-2008, 04:33 PM   #14 (permalink)
k20fg2SI's Avatar
yea i think so these car are ment to be driven at time hard so i dont think its nothing
Old 08-04-2008, 08:03 PM   #15 (permalink)
k20fg2SI's Avatar
o ok so its hard to put it into 1st when at a slow roll it feels like it hit a brick wall so i take it back out and try it agian and still hits a brick wall should i push harder or double clutch? and would anyone know wats wrong?
Old 08-04-2008, 08:39 PM   #16 (permalink)
08_Civic's Avatar
Gary
try going into 2nd and 3rd then go back to 1st. Play with the clutch a little. Make sure you have the clutch fully pressed. Im having this problem also. But the harder you push it, its not going to go in. I always held my hand there and give it a little force into 1st to make sure it goes in when im going to take off. If you dont do this then its going to grind and pop back out
08_Civic is offline   Reply With Quote
Old 08-04-2008, 08:43 PM   #17 (permalink)
k20fg2SI's Avatar
all the gears run threw good.. but sometime at like a stop sign not at a full stop puttin it into 1st it doesnt go in not all the itme at times ahh would this be something i would go to the dealer about? cuz it mite not happen when they test it out. should i be worried ?
Old 08-04-2008, 09:57 PM   #18 (permalink)
14.2@98 i/h/e
i never put mine in 1st unless im all the way stopped
Old 08-04-2008, 10:12 PM   #19 (permalink)
k20fg2SI's Avatar
ok so at a slow roll u drop it into second?
Old 08-04-2008, 10:15 PM   #20 (permalink)
08_Civic's Avatar
Gary
yeah im having that problem also. But take it to the "stealership" and tell them about it. But it happen to my old car. EG hatch. But to me im use to it. But yeah. Take it to the stealership and tell them your problem and see what they can do about it. I need to take mine to it too. Ive been holding it off for like 6 months now. xD "failed" But yeah. When at a stop (or rolling) and it doesnt want to go in, keep it in first gear, when it feels like it doesnt want to go into first give it a little force, slowly let off the clutch (while giving it a little force) and then give it a little gas and it should go in fully. It always works for me. Other than that mess with the clutch a little like go into first and if it doesnt go into it. Then go to second then third. Now go back into first. It SHOULD let you go into first. Try it and see what happens! Good luck!
My engine has a strong will to live! user Civic SI 26 06-27-2008 04:50 PM
How strong is our oil pans for the Si? AllShowNoGo Garage 3 03-15-2008 04:28 PM
blown trannys n e 1? all motor K'S Mechanical Problems & Technical Chat 11 03-13-2008 10:16 AM
