Old 07-18-2006, 01:36 PM   #1 (permalink)
My 2006 Civic Is Backfiring After Cold air Intake And Exhaust! Why?
I have a fujita F5 cold air intake and a magnaflow exhaust. after i installed the exhaust i can hear backfiring.
"Backfire in an automobile engine typically results from various malfunctions related to the air to fuel ratio. Usually, backfiring occurs in carbureted engines that are running lean where the air fuel mixture has insufficient fuel. ("Running lean" is typically a sign of mal-adjusted carburetors or fuel injection where there is not enough fuel for the amount of air). Afterfire, however, occurs in engines that have an exhaust leak or unburnt fuel in a decatted exhaust system. When a driver shifts up and lets off the gas, the engine has a moment of running rich or with insufficient oxygen. This causes an incomplete burn which causes the fumes to explode in the exhaust system. The leak itself is the most dangerous aspect. Without it, the mixture would cool enough not to explode. A fuel injected engine may backfire if an intake leak is present (causing the engine to run rich), or a fuel injection component such as an air-flow sensor is defective."
That's the defenition. I am running regular gas.
What cna I do to fix this? Any help will be greatly appreciated! Thanks in advance!
SkyeHack is offline   Reply With Quote
Old 07-18-2006, 02:06 PM   #2 (permalink)
Any check engine lights? Did you unhook the battery while installing ecu needs to reset to learn new fuel curve
dafdemon is offline   Reply With Quote
Old 07-18-2006, 02:08 PM   #3 (permalink)
no check engine lights. i didn't unhook the battery. how do i do that?
i would also like to mention that i have no resonator. could that be it as well?
Old 07-18-2006, 02:12 PM   #4 (permalink)
Gaspar_06_Civic_EX's Avatar
Shawn
is the the catback exhaust? I have the Fujita F5 and the magnaflow Catback exhaust with no problems.
Gaspar_06_Civic_EX is offline   Reply With Quote
Old 07-18-2006, 02:15 PM   #5 (permalink)
no, its a custom magnaflow exhaust with no resonator...
Old 07-18-2006, 04:05 PM   #6 (permalink)
Torredo
Guest
Posts: n/a
its normal for a sound of popping on MT models once
youve taken that silent granny exhaust off. I have
a V-force exhaust and it pops when i downshift a little
under bigger compression.
Old 07-18-2006, 07:28 PM   #7 (permalink)
Skylinegtr06's Avatar
edwyn(male)
Did you get your ecu reconfigured? I think the air sensor is confused about how much a fuel mix ratio is needed for the burn since its getting more air then normal
Old 07-18-2006, 07:55 PM   #8 (permalink)
JeShUa's Avatar
RIP J6
I'd try premimum and start running it hard,, see if that helps the car calculate it.. lets see what others have to say about what I have to say.. please be kind :]
Old 07-18-2006, 08:01 PM   #9 (permalink)
Photobucket
St Jude
Silver8th's Avatar
I had my resonator taken off, MagnaFlow put on and I don't get any backfiring or popping so I doubt that's the problem. I don't have an intake yet though.
Old 07-18-2006, 08:22 PM   #10 (permalink)
cappykd's Avatar
Kirk
Did you reset your ECU when you put the Fujita on? Disconnect your negative battery cable for about 5 minutes then once you reconnect the negative battery cable start your car and let it idle for about 15 minutes, then just go drive your civic to let the ECU learn. Drive it exactly the way you intend to normally drive it.
cappykd is offline   Reply With Quote
Old 07-18-2006, 08:55 PM   #11 (permalink)
If you saw the backfire in fact blow out your exhaust then there really is ecu problems. If you did NOT see it blow it...the lack of resonator can make it sound like it's popping or backfiring, while in fact...it isn't. Have someone look at your exhaust while you rev and let off right away. When both of you hear the sound, but does not have backfire flames come out...then it's the exhaust system's design. I might check into magnaflow's exhaust to see if there are any defects.
driveshift is offline   Reply With Quote
All-New 2006 Civic Si to Make Racing Debut Kabs Civic SI 12 11-01-2007 04:29 PM
Cold air/ cat back exhaust 2006SI Mechanical Problems & Technical Chat 7 04-16-2006 07:06 PM
Honda Civic SI 2006 Parts SpeedDemon Civic SI 2 03-30-2006 12:29 PM
2006 CIVIC SI WINS THUNDERHILL!! 2fast4u2 Civic SI 5 12-08-2005 01:17 PM
2006 honda world news webby Garage 0 07-25-2005 09:31 AM
