Old 07-25-2008, 01:04 PM   #1 (permalink)
kingkung's Avatar
oil change question
I am doing my first oil change. if i do it myself, does the oil life display automatically reset back to 100% or does the dealer need to reset it? I drive an 07 SI coupe
kingkung is offline   Reply With Quote
Old 07-25-2008, 01:08 PM   #2 (permalink)
after you change the oil you need to get into your car and hit the sel/reset button until it gets to your oil life. now hold that button for i believe 10-15 seconds and it should reset to 100
need4speed423 is offline   Reply With Quote
Old 07-25-2008, 01:10 PM   #3 (permalink)
kingkung's Avatar
ok...thank you very much.
Old 07-25-2008, 01:22 PM   #4 (permalink)
RiceBowL54's Avatar
Gio
This was new to me so I thought I'd share...
Make sure you get the code thats next to your oil life display.. i think its "A1" or "A2" or something like that. I just found out that the dealership uses that to determine what kind of maintenance the car needs.
This is explained in the manual, but I skipped over that part.
RiceBowL54 is offline   Reply With Quote
Old 07-25-2008, 01:40 PM   #5 (permalink)
harobmx87's Avatar
Sarandis
i just did this yesterday. hit the sel/reset button on the left till it gets to your oil life, hold it for 10-15 seconds. when your oil life starts flashing, press and hold the sel/reset button for 5 seconds or it says 100%
oh yeah... have fun with the oil filter =/
harobmx87 is offline   Reply With Quote
Old 07-25-2008, 01:58 PM   #6 (permalink)
tsltd's Avatar
Hang
oil gets all over the axle and everything very messy....
tsltd is offline   Reply With Quote
Old 07-26-2008, 12:46 AM   #7 (permalink)
kingkung's Avatar
i did my oil change this morning before work and then after work i went out to warm the car up before driving home, it seemed to have a little hard time starting. it started up the first try, but softly putted a couple times and then started up strong. does anyone know what this could be?
Old 07-26-2008, 02:54 AM   #8 (permalink)
dut
dut
I haven't seen the oil filter location on this car, but is there anyway you can put foil or something over the axle?
NM, you have an Si.. Different than my slower motor.
dut is offline   Reply With Quote
who goes by oil life? Oil percent, First Oil Change Oil Monititor Threads Merged Cora Mechanical Problems & Technical Chat 239 08-07-2008 11:46 PM
Oil Life In Months not Mile Fist Oil Change? Rolow Mechanical Problems & Technical Chat 27 05-11-2008 08:13 PM
thoughts-first oil change, mtf change norcal450 Civic SI 15 08-23-2007 07:29 PM
Is your dealer putting in the wrong type of oil, durring your oil change? Markstudy Garage 4 10-30-2006 09:08 AM
First oil change/trans fluid change BEFORE 3500 miles? djdefcon Civic SI 7 08-22-2006 09:36 AM
