Old 07-18-2008, 06:33 AM   #1 (permalink)
deltatechx's Avatar
need help removing clutch in my LX 1.8L
For those of you that have replaced your LX/EX clutch, what is the name of the socket needed to remove the bolts holding the pressure plate to the flywheel? Also, what size socket is needed?
Thanx,
-Paul
deltatechx is offline   Reply With Quote
Old 07-18-2008, 07:27 PM   #2 (permalink)
10mm 12 point for the clutch, 17mm 12 point for the flywheel.....if i remember right, should be 6 bolts each....
kentarou is offline   Reply With Quote
Stock clutch and NITTO NT01 don't mix. I need a clutch!!! itzwykd Forced Induction And Nitrous 50 07-25-2008 01:46 PM
Removing DX/LX/EX Spoiler...? jbsali Inside and Out 0 06-26-2008 03:05 AM
1.8L EX-DX-LX Lightweight Flywheel 7.5lbs Blackł Bolt-Ons And All-Motor 10 10-24-2007 10:59 PM
SRI on 1.8L Sedan Tikolx333 Garage 2 05-22-2006 05:18 PM
