Old 07-16-2008, 12:00 AM   #1 (permalink)
Maintenance Schedule
Does anyone know what the maintenance schedule is for the 08 SI? I looked through the book but it doesn't help. Thx
WraithSI25 is offline   Reply With Quote
Old 07-16-2008, 07:36 AM   #2 (permalink)
Mark
Look in the owner's manual for Maintenance Minder - not Maintenance Schedule. The Maintenance Minder shows codes when work needs to be done. You won't find a traditional "Maintenance Schedule"
etcthorne is offline   Reply With Quote
Old 07-16-2008, 08:04 AM   #3 (permalink)
Pedo Saiyan Level 2
dcubed121's Avatar
David
This car is idiot proof. when your oil is less then 15% it will tell you to change/check what needs to be done.
eg_) "A"=oil/oil filter change
"B"= above+check air filters+check fluid levels. etc,etc,etc
just do what the car tells you to.
dcubed121 is offline   Reply With Quote
Old 07-16-2008, 10:07 AM   #4 (permalink)
Slutty McSlut Slut
cderalow's Avatar
Chris
actually...
A= oil change
B= oil+filter change, plus visual inspection of fluids, brakes, suspension, exhaust
1= tire rotation
2= replace air filters, inspect serpentine belts
3= replace transmission fluid
4= replace spark plugs, check valve clearance
5= replace engine coolant
can be found on page 229 of the Sedan Owner's manual, 231 of the Coupe Owner's manual.
2008 Honda Civic Si Sedan Fiji Blue Pearl
FBP Crew #00
FA Crew #000
2007 Honda CR-V EX-L AWD Whistler Silver Metallic
HondaSUVForums Member
Old 07-16-2008, 07:13 PM   #5 (permalink)
Pedo Saiyan Level 2
dcubed121's Avatar
David
Originally Posted by cderalow View Post
actually...
A= oil change
1= tire rotation
i was going off memory. it's also in the maintenance book as well.
Maintenance Schedule and Pricing Menu striker_1818 Civic Coupe And Sedan 75 11-01-2008 12:31 AM
Order of maintenance minder schedule ilikemycivic Mechanical Problems & Technical Chat 6 05-13-2008 02:09 PM
aggressive maintenance schedule waaden Garage 5 04-16-2008 11:10 AM
where is the maintenance schedule? 2evolved Civic SI 4 06-13-2006 01:34 AM
Recommended maintenance schedule ? Rjc22NJ Garage 9 02-12-2006 08:40 PM
