Old 07-13-2006, 03:24 PM   #1 (permalink)
Typical. How Typical.
Special Ringpop's Avatar
License Plate Fitment
Okay, so this is really bugging me.
I just got my license plate in the mail (Michigan license plate, that's where my family lives), and the damn plate won't fit.
I can't screw more than one row of the two rows of screws in. Let me rephrase:
I can only screw the top two screws in, or the bottom two screws in, because the opposite row won't fit if I screw the others in.
Does this make sense to anyone?
I called the dealer I bought it from, and he said the bottom two screw holes are adjustable, but I think I'm calling bullshit, because my two bottom screw holes definately don't allow for me to put the screws in if I've already screwed the top two in.
I feel so stupid.
Originally Posted by ImTheVoiceofGod
This was basically the "your mom" of this conversation. A statement meant to mean "I have nothing usefull to contribute as all of my resources have been exhausted. But I am not man enough to admit this so I will now resort to childish bickering."
Special Ringpop is offline   Reply With Quote
Old 07-13-2006, 03:52 PM   #2 (permalink)
06blaksi's Avatar
I've owned about 15 cars in my life and I don't ever recall using more than 2 screws
Old 07-13-2006, 05:00 PM   #3 (permalink)
Supreme Pizza!
Izzy's Avatar
My plates fit with all four screwed in (well, the front plate is off, and those screws needed to be used!). I just screwed it in a thread so there's movement, then moved it around until I got them all into their holes.
Old 07-13-2006, 05:05 PM   #4 (permalink)
There's at least a good quarter of an inch between the holes lining up.
Old 07-13-2006, 05:07 PM   #5 (permalink)
Supreme Pizza!
Izzy's Avatar
Ouch! Well, you typically don't need FOUR screws in. I'll admit it looks better though...
If you want to...why not just put some caps on there, and fit them on without screws?
Old 07-13-2006, 09:17 PM   #6 (permalink)
I'm just curious as to why it doesn't fit. It fits on every other car my family owns.
Old 07-13-2006, 09:23 PM   #7 (permalink)
Photobucket
Silver8th's Avatar
EARL
Maybe you need to loosen the top two screws a little bit to get the bottom ones started and go from there.
Old 07-13-2006, 10:53 PM   #8 (permalink)
Fishytron's Avatar
i have michigan plates as well and have the same problem... pain in the ass rightt?
Fishytron is offline   Reply With Quote
Old 07-13-2006, 11:22 PM   #9 (permalink)
tennisfan16's Avatar
yeah this is the first car i have ever owned that had screw holes on the bottom and top
tennisfan16 is offline   Reply With Quote
Old 07-13-2006, 11:24 PM   #10 (permalink)
Supreme Pizza!
Izzy's Avatar
Are they shaped differently or something? That's odd.
Old 07-13-2006, 11:45 PM   #11 (permalink)
Fishytron's Avatar
mabey but i think the holes are ment for exact fitment (there is no play in the postion). it sucks and i need the bottom ones cause my sub bumps!!
Old 07-13-2006, 11:49 PM   #12 (permalink)
What the hell, Michigan.
My mom checked a few older license plates. Holes matched on one, and didn't on the other.
The guy at the deaelrship I bought it from said, "The bottom clips move up and down".
Mine definately don't.
Old 07-14-2006, 11:40 AM   #13 (permalink)
CoryB's Avatar
Cory
My guess is that the holes in the plates aren't placed evenly.
I always use 4 screws to mount my license plates. I put in one top screw loosely, then the opposite corner bottom screw. Then I put in the other two, and once all of them are started, I tighten them all up.
CoryB is offline   Reply With Quote
Old 07-14-2006, 11:51 AM   #14 (permalink)
CesarNYC's Avatar
Talking
I feel so stupid.
Are you talking about both the front and the back? You could try a license plate cover instead of a frame, push come to shove. I know that you don't need more then two screws, but personally if it only takes two nails to secure something I wind up using six.
CesarNYC is offline   Reply With Quote
Old 07-14-2006, 02:40 PM   #15 (permalink)
I'm talking about rear. Michigan doesn't require front plates.
I should've clarified, sorry.
You'd think Michigan plates, coming from Michigan, would be the best fitting :P.
Old 07-14-2006, 03:14 PM   #16 (permalink)
06blaksi's Avatar
The Si comes from Canada...maybe Canada uses a different spacing? :gaygiggle I'll check mine at break time, around 2:30. I know I took the dealer frame off but don't remember how many screws I put back
ok well I looked and I have 4 screws and the only adjustments I see are the oval holes in the plate and they're not even. I would think maybe when they made your plate they put holes are in the wrong spot..can you match it up to an old plate?
Old 07-14-2006, 04:19 PM   #17 (permalink)
Yes, one of my mom's old plates matches up pretty closely, but then another older plate, they are off by enough to be able to miss the hole
Old 07-14-2006, 04:50 PM   #18 (permalink)
JeShUa's Avatar
swagger so tight
his liscense plate is a cirle !
Sarcasm much
Old 07-14-2006, 08:22 PM   #19 (permalink)
CesarNYC's Avatar
I was putting in some license plate covers I picked today. I noticed in the back where the license plate mounts, "something" looks adjustable, my guess is the top screw placement IS adjustable. I didn't mess with the two plastic adjustable pieces because the holes are correctly spaced, and I wouldn't stake my life on it, but I think the dealer was telling you the truth. Why would you have two adjustable white plastic pieces directly behind the license plate. Any brave Michigan souls willing to test my theory?
Old 07-14-2006, 08:46 PM   #20 (permalink)
Are you talking about the bottom two screw holes, or the top most screw holes by the trunk lid?
Finally figured out what custom license plate to get! Fixer Garage 18 01-18-2007 10:36 AM
offensive license plate webby Water Cooler 21 07-20-2006 10:40 PM
Ebay best for CF license plate frames?? OHSiGuy Inside and Out 9 07-13-2006 11:35 PM
CARBON FIBER LICENSE PLATE strCIVIC Inside and Out 5 06-01-2006 09:58 AM
