Alignment and or camber kit - 8th Generation Honda Civic Forum
Old 07-13-2008, 05:17 PM   #1 (permalink)
Nate
Ok ok.. Yes I know there are other posts about this and I have read a bunch of posts about this but none really answer my question.
I have H&R springs 1.6 F, 1.3R. I was waiting for my springs to settle before I got an alignment. I've been busy and that was like 2 months ago. Anyway the rear tires are going bald on the inside of the tires. The rear wheels sit like this /.....\
So are my tires going bald because of the need of an alignment or because I need the camber kit. I don't care about performance handling, I just want my tires to last longer. Didn't think I'd need a camber kit since the drop is 0.3 inches more than HFP kit which doesn't require them.
Thanks
Mr Big is offline
Old 07-13-2008, 05:42 PM   #2 (permalink)
You need an alignment. If there is insufficient adjustment to correct your negative camber then you will need a camber kit.
TrekRider is offline   Reply With Quote
Rear camber fixed, alignment sheet, and ?? for experts. 06NaviEX Mechanical Problems & Technical Chat 7 08-05-2008 11:01 PM
Too much negative camber? Front camber kit review aki Suspension and Brakes 11 06-20-2008 03:26 AM
I have my skunk2 rear camber on but still havent gotten an alignment vince1128 Suspension and Brakes 3 05-11-2008 03:39 AM
alignment and camber azndawei Suspension and Brakes 2 02-20-2008 02:30 AM
Installation/alignment places for Camber kit + Spring install I Vtec, do you? Suspension and Brakes 20 02-07-2008 05:10 AM
