adjusting valves - 8th Generation Honda Civic Forum
Old 07-13-2008, 09:00 AM   #1 (permalink)
adjusting valves
has anyone had to have their valves adjusted due to noise, and what mileage was on the car, and how did it sound, and cost to get it fixed.
sethscivic is offline
Old 07-13-2008, 09:28 AM   #2 (permalink)
RWatters's Avatar
It's done at 60,000 miles IIRC. As time goes by the valves will start to tick and get a little louder so if you're just starting to hear a little noise I wouldn't be concerned about it. You could also be hearing the fuel injectors ticking. When I asked Honda about it they stated they would not do it any earlier than what the maintenence scheduler stated.
As far as cost goes, I believe it's in the $200-$300 range?
RWatters is offline   Reply With Quote
Old 07-13-2008, 10:59 AM   #3 (permalink)
Brian
Wow so these newer honda engines still need valve adjustments? I have the 08 civic Si is that engine auto adjust the valves or does it have to be done manually like an old isuzu LOL? I think toyota engines are auto adjusting valves, I sure hope honda engines are too to keep up in competition with toyota?
baglenn77 is offline   Reply With Quote
Old 07-13-2008, 12:46 PM   #4 (permalink)
yes newest honda's still need valve adjustments, however it doesnt specifically say at 60k miles it says whenever A B 1 2 or 3 maintainence codes come up adjust only if they are noisy, my original question, was has anyone had their valves get noisy on them yet, regardless of interval service, and if you could hear them make noise how many miles were on the car???
sethscivic is offline   Reply With Quote
Old 07-13-2008, 06:38 PM   #5 (permalink)
Hydraulic lash adjusters just wear out eventually. At least with manual adjustment you never have worry about it.
killsw1tch is offline   Reply With Quote
Old 03-30-2009, 05:03 PM   #6 (permalink)
JDMFG2SI's Avatar
Juan
Holly Thread revival!!
I have 12k miles on mine and my valves are ticking. WTF!
JDMFG2SI is offline   Reply With Quote
Old 03-30-2009, 05:47 PM   #7 (permalink)
Stephen
^^ you misshifted.
$$ shift ftl.
:P
w00t692 is offline   Reply With Quote
Old 03-30-2009, 06:25 PM   #8 (permalink)
Supa Ninja's Avatar
Nick
51,000 they were ticking loudly. Had several loose intakes, and a couple tight exhaust. Did it myself, wasn't difficult, and took all of 2 hours. Idles smoother now, just hear the injectors, and it got rid of some of the cold first gear bucking. Didn't know it would be that expensive to have a stealership adjust them. DIY FTW!
Supa Ninja is offline   Reply With Quote
Old 03-30-2009, 07:35 PM   #9 (permalink)
Stephen
It's not. Valve adjustment is not 200-300 dollars. More like 150 tops.
Old 03-30-2009, 07:37 PM   #10 (permalink)
hondaonchrome's Avatar
Lonny
what is involved in adjusting them?
hondaonchrome is offline   Reply With Quote
Old 03-30-2009, 07:49 PM   #11 (permalink)
asdf's Avatar
rich
a feeler gauge, your typical sockets and ratchet, torque wrench, a modded open ended wrench, the correct valve lash for the intake and exhaust side and a cold motor. its pretty easy, but i haven't done it on kseries yet.
asdf is online now   Reply With Quote
Old 03-30-2009, 08:33 PM   #12 (permalink)
nsane's Avatar
Sean
or the proper jam nut tool
nsane is offline   Reply With Quote
Old 03-30-2009, 08:51 PM   #13 (permalink)
asdf's Avatar
rich
haha i didn't want to buy one, works fine.
Old 03-30-2009, 09:10 PM   #14 (permalink)
ebdiam's Avatar
Evan
Will you run into problems if they are not adjusted?
I've never heard of this before...
ebdiam is offline   Reply With Quote
Old 03-30-2009, 09:14 PM   #15 (permalink)
asdf's Avatar
rich
Pretty much everything in your head will wear down more and more, like the valvetrain, cams...etc. Which would lead to less power and bad gas mileage.
Old 03-30-2009, 09:27 PM   #16 (permalink)
sh33t_0f_p4p3r's Avatar
Tobie
i called my honda dealer and they said 99$
sh33t_0f_p4p3r is offline   Reply With Quote
Old 03-30-2009, 09:34 PM   #17 (permalink)
asdf's Avatar
rich
You can find reputable people they will do it for half or less than half that. But that's a good price from a dealership.
Old 03-31-2009, 07:54 AM   #18 (permalink)
Stephen
it's usually an hour of labor they charge.
so 100-150 is pretty much all that will be charged.
Old 03-31-2009, 07:54 AM   #19 (permalink)
Supa Ninja's Avatar
Nick
if you have tight exhaust valves you run the risk of having burnt valves. Definitely a good thing to have checked if you have a lot of mileage.
Old 04-08-2009, 01:15 PM   #20 (permalink)
JDMFG2SI's Avatar
Juan
Originally Posted by w00t692 View Post
^^ you misshifted.
$$ shift ftl.
:P
LOL You got it!! I misshifted a couple of times and bounced it off the rev limiter
sympthom's of bend valves slow4drsi Mechanical Problems & Technical Chat 7 05-01-2008 05:07 PM
Noisy Valves on Si Sedan HondaFamilyMan Civic SI 14 01-20-2008 04:53 PM
I hope I dont have bent valves. JOKINGFG2 Mechanical Problems & Technical Chat 26 04-15-2007 09:23 PM
How often should valves be adjusted? robck Mechanical Problems & Technical Chat 4 04-05-2006 10:20 PM
