Old 07-09-2008, 01:42 AM   #1 (permalink)
Rocky Vibrock
Check Engine Light On... I want it off
Problems with intake and hondata
Hi,
I have an AEM Intake and Hondata in my 2007 Honda Civic Si Sedan. I've had them for about 8 months now with no problems. About a month ago the check engine light came on. It turned out to be an emissions sensor. A few weeks later it came on again. When I took it to the dealership they said that the light was coming on because of the aftermarket intake. Again this light never came on before and when it did come on the first time it was for a faulty sensor. They reset the sensor and its on again. Has anyone had any problems with these upgrades? Any suggestions or comments would be greatly appreciated.
Thank you
t_rock_01 is offline   Reply With Quote
Old 07-09-2008, 01:44 AM   #2 (permalink)
thisisdudewhoru's Avatar
brian
I think I remember the first batch of AEMs caused cel's but not sure if this is related or not
thisisdudewhoru is online now   Reply With Quote
Old 07-09-2008, 08:44 AM   #3 (permalink)
Rocky Vibrock
Do you know if AEM did anything to correct this?
Old 07-09-2008, 03:48 PM   #4 (permalink)
brian
I know that most of the people that bought newer ones did not have a problem.
Old 08-21-2008, 07:54 PM   #5 (permalink)
Hope I am not too late to respond to your question! This is Sami from AEM. I would urge you to take a look at the airflow straightener/coupler. Incorrect installation of this component could lead to the symptoms you're having with your car. The purpose of the straightener is to smooth the turbulence of the airflow just before it hits the MAF sensor. This will keep CELs away and ensure you're not running too rich or too lean.
Here is the airflow straightener/coupler
This is how to correctly install/align the airflow straightener with the MAF sensor
Now, this is an INCORRECT installation. Don't try this on your car!
AEMSS is offline   Reply With Quote
Old 08-21-2008, 08:06 PM   #6 (permalink)
02civicsi's Avatar
I am the Juggernaut!!!
I don't see any pics.
02civicsi is offline   Reply With Quote
Old 08-21-2008, 08:47 PM   #7 (permalink)
speedracex's Avatar
I see em
speedracex is offline   Reply With Quote
Check Engine Light - Tried everything, double check my install? Yodums Bolt-Ons And All-Motor 45 11-01-2008 10:11 PM
CHeck engine light!! Johannes Mechanical Problems & Technical Chat 24 04-30-2008 05:07 PM
Check engine light ?! cambodianricer Mechanical Problems & Technical Chat 15 12-31-2007 06:58 PM
Engine Check Light................ NoMoreHonda Mechanical Problems & Technical Chat 19 09-18-2007 10:47 PM
Check engine light Wrathchild Civic Coupe And Sedan 6 12-19-2005 12:41 PM
