Old 07-04-2008, 01:58 PM   #1 (permalink)
08lxciviccoupe's Avatar
Clay
Speed Shifting
Now I am an old fart so I hope I explain this the right way, when merging into traffic from first to second I hit the accelerator to about 5000RPM or so and shift into 2nd and it jerks badly same thing for 2nd to 3rd? Is this normal for the newer Hondas? My Old CRX didn't do this, its like trying to bark a tire in 2nd even though I honestly am not trying to, just to get up to flow of traffic quickly. I have driven a manual all my life so I am not a newbie, took it to the dealershit and they said it was normal but I don't believe them. If you understand what I am saying if not I will try and clarify it.
08lxciviccoupe is offline   Reply With Quote
Old 07-04-2008, 02:13 PM   #2 (permalink)
KraziAzn's Avatar
David
break-in period?
KraziAzn is offline   Reply With Quote
Old 07-04-2008, 02:22 PM   #3 (permalink)
Clay
Car has 3,000 miles on it, I found another thread that describes it here is the link
Aggressive driving and shifting?
Old 07-04-2008, 02:23 PM   #4 (permalink)
They Call Me TK's Avatar
Troy
make sure you watch the tach, this throttle by wire system does lag and hesitate a little and does take some getting used to if you've driven cable throttles your whole life. when you shift from gear to gear make sure you see the tach drop at least 1000 rpm's then release the clutch, you should be fine then. if you have the ac on the tach will drop faster than if you didn't have it on due to more load being applied by the compressor... again just watch the tach and make sure it drops before you shift.... but don't let it drop too much or it'll lurch again. you'll figure it out.
They Call Me TK is offline   Reply With Quote
Old 07-04-2008, 02:26 PM   #5 (permalink)
ATL Squad Member #33
06GAsi's Avatar
Yeah DBW. You should get used to it.
Ooooowwwwweee. I cant' believable, like a little girl!
http://www.8thcivic.com/forums/water...dell-tech.html
06GAsi is offline   Reply With Quote
Old 07-04-2008, 02:37 PM   #6 (permalink)
I have an '07 lx and haven't had any problems shifting. First to second is smooth, unless I screw something up and and don't get the RPM matching well, but that's my fault and has nothing to do with the vehicle. Since you're revving to about 5,000 rpm in first, you're going to get some rev hang so you'll have to account for that in your shift timing. If you shift very quickly, your engine will still be at a higher RPM than it should be for your speed in second gear. That would explain why the car lunges a little when letting off the clutch, especially if you're giving it more fuel before you let off the clutch.
Try adjusting how you drive a little. Normally you let off the gas and hit the clutch at the same time in a manual tranny, but try letting off the gas a half a second earlier so you get less rev hang and likely smoother shifts. I have a feeling you'll just have to get used to the drive by wire and make adjustments.
Itchytoe is offline   Reply With Quote
Old 07-04-2008, 02:42 PM   #7 (permalink)
cambodianricer's Avatar
Jason
drive by wire FTL!!!!
cambodianricer is offline   Reply With Quote
Old 07-04-2008, 02:47 PM   #8 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
I speak "old fart". lol
Just control the clutch more to reduce jerkiness. Sometimes I will intentionally shift hard to get the chirps when I'm "in the mood."
CLICK--> TOYS FOR TOTS
Old 07-04-2008, 04:14 PM   #9 (permalink)
Clay
I will try this I am used to the "old fart" clutches.
I haven't been able to "chirp" the tires yet.....Unless I double clutch it,
Old 07-04-2008, 05:07 PM   #10 (permalink)
TWFA5FTMFW
0720Steve's Avatar
Resident Si Sedan Hater Hater
does it do it all the time? is it cold at the time.....just after being started up?
0720Steve is offline   Reply With Quote
Old 07-04-2008, 05:41 PM   #11 (permalink)
Blktrax's Avatar
Adam
I still have this issue also, having a crx and this new car. I've just had to train myself to not compleatly lift off the throttle when shifting.
Blktrax is offline   Reply With Quote
Old 07-04-2008, 07:01 PM   #12 (permalink)
Clay
Its always warmed up when it does it, its basically waht the guy below says I have to relearn how to drive again......
I understand this completely.
Old 07-05-2008, 02:15 PM   #13 (permalink)
Troy
You can remedy the problem with this sprint booster Sprint Booster Plug n Play Performance - - www.SprintBoosterSales.com . Good luck justifying the $329.95 price though
Old 07-05-2008, 08:17 PM   #14 (permalink)
JewUnit804's Avatar
Alex
learn to shift? lol jk
JewUnit804 is offline   Reply With Quote
Old 07-05-2008, 08:59 PM   #15 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
I wonder what they'll do if it fries your CPU.
Old 07-05-2008, 09:02 PM   #16 (permalink)
Dickotine's Avatar
Born2xceler8
yup its the drive by throttle. Just keep practicing, you'll eventually learn how to eliminate that jerking with good clutch pedaling
Dickotine is offline   Reply With Quote
Old 07-05-2008, 11:48 PM   #17 (permalink)
Troy
Sprintbooster sends an improved signal to the ETC (Electronic Throttle Control) which is amplified or "boosted" so that throttle is noticeably more responsive throughout the entire rpm range. Why would it fry the cpu??
Old 07-06-2008, 12:08 AM   #18 (permalink)
nayilsi's Avatar
ride the clutch a little bit longer.
Old 07-18-2008, 01:07 PM   #19 (permalink)
jaxson's Avatar
Your right. Riding the clutch a bit at the last second before fully taking your foot off the clutch going into secodn seems to do the trick. I dont really see an issue from 3rd gear and on. However I now question the life of my clutch.
jaxson is offline   Reply With Quote
Old 07-18-2008, 01:17 PM   #20 (permalink)
Clay
LOL it seems as if I am having to "learn" to drive again anyways.
I am practicing in this stop and go go go go stop go go go STOP traffic here. Trust me.
I question this as well
Display Speed vs Actual Speed csxian Wheel And Tire Upgrades 6 06-08-2008 11:59 PM
shifting. Zeuceone Mechanical Problems & Technical Chat 8 01-14-2007 03:41 AM
WOT Shifting dannyboy's06Si Autocross & Sanctioned Drag Racing 38 08-24-2006 09:05 PM
Shifting Nathan Mechanical Problems & Technical Chat 10 03-15-2006 05:32 PM
Shifting Down Scotty Mak Mechanical Problems & Technical Chat 11 12-27-2005 01:02 PM
