Old 06-23-2008, 04:17 PM   #1 (permalink)
FijiSan's Avatar
justin
extended oil life?
so after switching to Royal Purple, how much more past the maintenance minder can i go without having to do an oil change??
FijiSan is offline   Reply With Quote
Old 06-23-2008, 07:34 PM   #2 (permalink)
Rolow's Avatar
I'm in for an answer because I'm not positive. From what I understand the Maintenance minder is smart enough to still be accurate after the switch to synthetic.
Rolow is offline   Reply With Quote
Old 06-23-2008, 08:40 PM   #3 (permalink)
FijiSan's Avatar
justin
hmm...well i don't know, hence the thread, hopefully the motor gurus will pop their heads in here....
Old 06-23-2008, 08:47 PM   #4 (permalink)
4-1
chrisfrofro's Avatar
Chris
i still do one every 4-5k miles even though i run Mobil 1 full synthetic
chrisfrofro is offline   Reply With Quote
Old 06-23-2008, 08:50 PM   #5 (permalink)
R4DG's Avatar
Kin
the maintenance is not a sensor in the tank that is designated to "know" what kind of oil you are using
it is a calculator that gives an estimate of oil life by a number of factors including hot runs, starts, run time
the maintenance will not know if you are running synthetic, my rule is follow the super expensive calculator and skip the "extended life" hype
R4DG is offline   Reply With Quote
Old 06-23-2008, 08:57 PM   #6 (permalink)
James
wut chris said 4-5k i push 5k
vit0 is offline   Reply With Quote
Old 06-23-2008, 08:57 PM   #7 (permalink)
Blktrax's Avatar
Adam
Castrol Syntec - Still every 5K.
Too may horror stories, I espically love the One Year/15k Amsoil. Then can't figure out why its pushing blue smoke out the back with less then 60k on the clock.
We've already replaced 2 R18's from lack of maintaince.
Blktrax is offline   Reply With Quote
Old 06-24-2008, 12:39 AM   #8 (permalink)
Only way to tell for sure is to get it tested (that's what I'm doing)
Blackstone Laboratories - Gas Engines
After I get the factory fill out I'm going to sample @ 3k and 15% to see if for my driving conditions (cold winters & short trips) the oil will hold up.
ilikemycivic is offline   Reply With Quote
Old 06-24-2008, 07:03 PM   #9 (permalink)
when I asked this question at a local oil change place, I was told it would not be the oil that would fail first, it would be the filter. So they want you to still follow the recommended MM schedule.
civicSQ is offline   Reply With Quote
Old 06-27-2008, 05:06 AM   #10 (permalink)
nayilsi's Avatar
always learning new things.
Old 06-27-2008, 07:58 AM   #11 (permalink)
boltuprite's Avatar
Gary
I don't get why people have to muck around with this.
Honda made it pretty simple. When the maintenance minder gets down to 15% oil life, you go have an oil change. I mean how difficult is this?
boltuprite is offline   Reply With Quote
Old 06-27-2008, 08:13 AM   #12 (permalink)
Synthetic Oil, Mobil 1
For what it is worth, a friend is a Petrolium Salesman and I consider him to be 'very' knowledgeable on the subject. ( His company does NOT sell Mobil products). When I told him I was using Mobil 1 and still changing my oil & filter every 3-5000 miles as I did with the non synthetic, he said I was "wasting my money".
He said,"there is NOT anything that car COULD POSSIBLY do to hurt that oil" !
"He would not change it for 10,000 miles minimum !"
" If you really insist on doing something, change the Oil Filter at 5,000 miles and refill as needed and then run it to 10,000 miles, then change oil & filter.
I just switched over to Mobil 1 on this car (08 Civic EX) at the last oil change (wanted to break-in motor first / old fashioned) so have not set a procedure yet. I think I am going to change it at 5,000 miles the first time, and take a sample to him for analysis. Depending on the results of it, I will make a determination for future oil change intervals.
jp-1 is offline   Reply With Quote
Oil Life In Months not Mile Fist Oil Change? Rolow Mechanical Problems & Technical Chat 27 05-11-2008 07:13 PM
Oil changed, but oil life won't reset!! Plz help!!!11 MurderedOut08Si Mechanical Problems & Technical Chat 4 03-21-2008 07:39 PM
Got my oil changed but my oil life is at 30%? That_Si_Guy Garage 20 02-12-2008 11:53 AM
Do you go by miles or oil life reading for oil change? nsl Do It Yourself Articles 4 08-03-2007 08:14 PM
Oil life question Harokot Mechanical Problems & Technical Chat 7 06-01-2007 11:42 AM
