High Beam question
Are the high beams allowed to come on by themselves? I noticed this when installing yellow DRLs...
With low beams off: When i pushed the stalk foward, the high beams would not turn on, nor would the indicator turn on. When i pulled the stalk toward me (flash-to-pass), the highs WOULD turn on, BUT my low beams would also turn on. With low beams on: When i pushed the stalk foward, the high beams would turn on. When i pulled the stock, they would also turn on. I know this is normal. I'm concerned about "with low beams off". When flash to pass, are the lows supposed to come on? Or did i mess some wiring up when installing PNP a while ago. Also, are the highs not supposed to come on without the lows? Thanks another question... I accidently touched one of the old DRL bulbs. Would isopropyl alchohol clean it? Last edited by asndragonboii; 05-10-2008 at 11:24 AM. |
Yes, on our Civics, all 4 bulbs are on when the high beams are on.
I used to have an old Saturn that had the same 9004/9005 combo, and the lows would turn off when the highs were on. I like all 4 on, since you get the distance and close to the car illumination. Plus it's bright as hell when you have to flash some drunk bastard on the highway who won't dim his lights LOL! Wiping the bulb with the alcohol should be fine. You just want all the oil from your skin off it. |
the DRLs are your daytime running lights, they put low voltage through your high beams so that other cars can see you better during the day, they come one when your headlights are off and your car is in drive (auto tranny) or you release your parking break (manual tranny). The fuse is in the fuse box next to the hood release it's labeled "DRL". I highly suggest you pull it.
No lol. I guess thats why we werent really understanding each other lol
I have HIDs in my Lows. When my lows are off and i flick my highs on, my lows will turn on with the highs. I just wanted to know if the lows were supposed to come on when i flash the highs. |
#14 (permalink) |
also means if you have PnP HIDs in your lows that they will attempt to turn on when you "flash to pass"...try not to turn on and turn off the HIDs in quick succession as it will lower the overall life of the bulb. as for cleaning the old drl with isopropyl, I'm not sure if that would work, don't see why it wouldn't, but I don't know what would happen so don't quote me on that.
PS: when your panic button/"alarm" goes off it flashes the low beams on and off which could potentially damage the HID bulbs...I'm currently trying to figure out how to disable that. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| HIDs turn on with high beam | iknowmysh1t | Lighting, H.I.D.'s, & Neon | 14 | 10-12-2007 02:32 AM |
| High Beam bulb question | Bandit03 | Lighting, H.I.D.'s, & Neon | 15 | 08-30-2007 08:20 PM |
| replacing high beam blub | AznSupastar | Lighting, H.I.D.'s, & Neon | 9 | 07-26-2007 02:43 PM |
| quick question: high beam or low beam | falkon57 | Lighting, H.I.D.'s, & Neon | 0 | 02-24-2007 12:42 PM |
| High Beam/9005 Question | monkey323i | Lighting, H.I.D.'s, & Neon | 7 | 07-25-2006 05:36 PM |
