Old 05-08-2008, 12:08 PM   #1 (permalink)
gui
Gui Rodrigues
White High beams/DRL
I'm looking to get some regular bulbs for my highbeams/drl's that will somewhat match my 4300k HID lowbeams...
I'm not sure what bulb I need to buy.. I saw someone elses post that I guess is looking for the same thing I am, and I was also thinking maybe I need silverstars... Has anyone done this to their DRL/highbeams that can tell me what bulbs I should get.. and does it even look good to have white drls?
Currently, I have "super white" fog light bulbs that came in my fog lights that match my 4300k HIDs perfectly... they look like regular bulbs but with a blue tint.... any input is appreciated
gui is offline
Old 05-08-2008, 12:12 PM   #2 (permalink)
jackolee's Avatar
4300k is like yellow right>???
all i know is that you cant change the drl color.
becasue the car is only letting a low amount of power into the bulb and that wont be enough to change the bulbs color
i think that is what your asking right? the lights that are on when you start up the car
jackolee is online now
Old 05-08-2008, 12:18 PM   #3 (permalink)
gui
Gui Rodrigues
4300k is supposed to be the "pure white" or as white as you can get before it starts getting blue...
as for the DRL color, I understand that it's not gonna look bright white when the DRL's are on cause of the low power going to the light but at least it shouldnt look orange/bronze like it does with the stock bulbs, and when my highbeams are on, those should look white...
so basically, im looking for a recommendation of what bulb i should get. if anyone has pics of someone whos done this that would be great too, and what bulbs they used.
gui is offline
Old 05-08-2008, 12:21 PM   #4 (permalink)
jackolee's Avatar
oh okay, well you can try getting the HID 4300k 9500 size bulb
Old 05-08-2008, 12:24 PM   #5 (permalink)
gui
Gui Rodrigues
you cant put hid's in for high beams considering that you mostly flash your high beams and turn them on and off and hid's arent meant to be flashed or they will burn out. thats why i need a regular halogen bulb with the color temp that matches a 4300k hid bulb, or something similiar... maybe even whiter
gui is offline
Old 05-08-2008, 12:32 PM   #6 (permalink)
Hang
i also would like to find out, im gonna be running 4300k hid's soon.
tsltd is online now
Old 05-08-2008, 12:54 PM   #7 (permalink)
jackolee's Avatar
theres a really bright white bulb called... i think "star dust" something like that, i dont remember. go to auto zone and look
Old 05-08-2008, 12:58 PM   #8 (permalink)
asm 06sedan's Avatar
Yusif
Hows 4300 HIDs cause Im planning to get them soon for my low beams and do they light up the road much better than regular hallogens?
About the high beams I read somewhere that silverstars will do it but don't remember where! Can some one confirm this?
asm 06sedan is offline
Old 05-08-2008, 01:00 PM   #9 (permalink)
jackolee's Avatar
^yea thats the name iwas trying to think of kept thinking it was called "star dust"
Old 05-08-2008, 01:50 PM   #10 (permalink)
djdisturbed's Avatar
Chris "DJ Disturbed"
the siverstar ultra still appear yellow when DRL's are on, but are not bad normal (i took the DRL fuse out b/c i dont like the yellow look). the closest to HID bulbs w/out going full HID would be to use HIR bulbs.
djdisturbed is online now
Old 05-08-2008, 02:33 PM   #11 (permalink)
gui
Gui Rodrigues
hir bulbs are pretty pricey tho arent they? im looking for a quick cheap bulb swap that will give me something as close to as i can get to matching my 4300k's.. i was thinking about the silverstars but i know some ppl said there are 2 diff types, thhe american sylvannia, and then like the OSRAM ones that are better or something... anyone have more info?
as for the 4300k's. they are A LOT brighter then the stock bulbs... they light up the road A LOT MORE... my gf has an ex sedan with stock headlights and when i drive her car after driving mine for a while i really notice the difference....
and as far as i know, 4300k's will give you the most light output of all temps because the bluer you go, the more light output you lose..
gui is offline
Old 05-09-2008, 03:42 PM   #12 (permalink)
gui
Gui Rodrigues
So has anyone done this mod? some input would be appreciated.
gui is offline
Old 05-09-2008, 03:55 PM   #13 (permalink)
there are 2 diff types of silverstars,
silverstar
and
silverstar ultra
sylvannia and osram are the same company
the silverstar ultra are the almost SAME price as HIR's....
a set of silverstar ultra's = ~$50/pair
HIR (single) = ~$27/each
plus any non HID bulb is going to appear yellow/orange when in DRL mode, just pull the DRL fuse and turn them off if you dont like it, it wont mess up anything else if you do this, I think the DRL fuse is #37 on the inside fuse pannel, but check you manual to make sure.
Old 05-09-2008, 04:03 PM   #14 (permalink)
gui
Gui Rodrigues
im just trying to find a bulb that will look white when the high beams are on. im not concerned with the DRL mode..
i dont know what color temp silverstars are but im looking to match 4300k hid's. im probably gonna go with like a blue tinted bulb.. i dont want something expensive
gui is offline
Old 05-09-2008, 04:20 PM   #15 (permalink)
then i will say go with the silverstar ultra's b/c they last much longer then the normal silverstars and alot of the other aftermarket "hyper white" type of bulbs.
Old 05-10-2008, 10:42 AM   #16 (permalink)
gui
Gui Rodrigues
how white are they?
gui is offline
Old 05-10-2008, 05:16 PM   #17 (permalink)
they are fairly white, not as bright white as the HIR's but not bad either.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
High Beams not level? fiji06si13 Lighting, H.I.D.'s, & Neon 22 05-12-2008 06:22 PM
Yellow High Beams imdanchu Lighting, H.I.D.'s, & Neon 21 01-18-2008 04:32 PM
High Beams msjwild3 Lighting, H.I.D.'s, & Neon 6 12-24-2007 05:48 PM
JDM Yellow High Beams at last! fiji06si13 Lighting, H.I.D.'s, & Neon 59 05-10-2007 05:59 PM
What are all of you HID owners doing for your DRL / High Beams? cappykd Lighting, H.I.D.'s, & Neon 37 02-28-2007 05:46 PM
Powered by vBulletin® Version 3.7.0
