did i plug the right thing in on my hid harness ?? pic inside
did i plug this in the right slot on the top ballast,, the bottom one is how it came in the box not pluged in i jstu wanna know if i pluggged it in teh right one top ballast lmk ( i dunno y it would not come plugged in already ?? unless teh oem harness goes into there ??? ) lmk thanks
on this setup (which is the best and a newer hid kit) the ignitor/relay/ballast are all in one. All you have to do is plug the stock harness into the harness near the light bulb. this is considered a plug and play kit. but yes you should ground the ballast with a screw inside the wheel well below the back of the headlight assembly to resist vibration and water damage
| H-9 Plug and Play harness EMU | Ljineus | Bolt-Ons And All-Motor | 0 | 04-02-2008 04:53 PM |
| HID through Factory harness or Through seperate harness with relays? | snpgotyou | Lighting, H.I.D.'s, & Neon | 17 | 01-18-2008 10:39 AM |
| K2 fog harness.. Mystery plug? | Rownan | Lighting, H.I.D.'s, & Neon | 3 | 04-22-2007 01:08 PM |
| Where did u place ur ballast (plug & play HID)? | AznSupastar | Lighting, H.I.D.'s, & Neon | 38 | 01-03-2007 03:58 AM |
