View Poll Results: Which bulbs should I get with my HID kit for my fogs?
Yellow 3000k bulbs 18 50.00%
White 4300k bulbs 18 50.00%
Voters: 36. You may not vote on this poll
Old 05-04-2008, 03:03 AM   #21 (permalink)
Firestrife's Avatar
Keenan
first off color of the bulb has nothing to do with how much power the halogen bulb is pulling if its 55w your good.
Firestrife is offline   Reply With Quote
Old 05-04-2008, 04:25 AM   #22 (permalink)
Smartass comment here...
kpSTI's Avatar
We are talking about HID's here not halogen. Thanks though.
kpSTI is online now   Reply With Quote
Old 05-04-2008, 02:13 PM   #23 (permalink)
deltatechx's Avatar
I have 6000k HID's. I plan on getting oem fogs with 6000k bulbs to match headlights.
1. will the bulb for the fog be too strong and burn out the wire of the oem wiring?
my first impression also was that he planned to use 6000K halogens to match his HIDs
If you are, then your harness will be fine if you use 55 watt bulbs. If you plan to use 100 watt bulbs then just use a relay to pull power directly from the battery.
deltatechx is online now   Reply With Quote
Old 05-06-2008, 03:34 AM   #24 (permalink)
Mok_speed's Avatar
Originally Posted by ASHRAF View Post
is it illegal to have yellow fogs?
I thought only red and blue are illegal
I'd say go 3000k, that's what i'm doing soon
Dunno but I was in my friend's civic and he got pulled over for having them on. He's got yellow HID fogs too. Maybe the cop was just being a lil biznatch?
Mok_speed is offline   Reply With Quote
Old 05-06-2008, 02:54 PM   #25 (permalink)
D3liri0usK's Avatar
John
Wow, the poll is split 16/16. I voted for 3000k because my experience with HIDs is that it's hard to see when it rains so you need something to balance the two out. I had an old e46 oem retro setup and yellow fogs with my old ek. I see better with halogens with my current fg2 in the rain, even though I'm in the process of doing a tsx oem retro setup. In my opinion yellow fogs are better than higher kelvin lighting for rainy/foggy conditions. I'll be using yellow fogs when its all said and done.
Yeah, the cop was being a biznatch.
D3liri0usK is offline   Reply With Quote
Old 05-06-2008, 04:51 PM   #26 (permalink)
Firestrife's Avatar
Keenan
yea i wasnt talking to you though.
Old 05-07-2008, 04:13 AM   #27 (permalink)
deltatechx's Avatar
You could always go for a 55 watt HID kit for your fogs, only use them when there's no other cars around (only time you actually need extra lighting) -- the glare off a wet road from these are unbelievable, lights up the trees on the side of the road like your friggin high beams are on :P But these are seriously amazing for bad weather driving.
yellow lens - what temp HIDs? juji88 Lighting, H.I.D.'s, & Neon 20 04-14-2008 04:07 PM
Can anyone with the K2 fogs tell me the wattage of the bulb? NHBlack07SI Lighting, H.I.D.'s, & Neon 0 10-20-2007 12:31 PM
Can't Decide on Fogs to match Retrofit CivicBeater Lighting, H.I.D.'s, & Neon 21 10-01-2007 11:33 PM
Ordering hids but dont know the bulb size 2007 civic skippy911 Lighting, H.I.D.'s, & Neon 5 03-23-2007 04:10 PM
lowest temp and hottest temp on outside temp gauge hondasi006 Water Cooler 16 01-29-2007 03:33 AM
