Old 04-20-2008, 09:47 PM   #1 (permalink)
Chyeaa
Tredd's Avatar
Ebay foglight install trouble
Just got some ebay fogs, but i picked them up from the vendor themselves. Ofcourse it didnt come with instructions they said something about it should hook up like the oem ones and blah blah blah. I installed the foglights them selves with ease, except the 1 pin connector plug didnt fit, so i had to take the white plug off and stick the 1 pin connector in by itself and tape it up. But the thing that threw me off was the interior foglight switch installation. The cables it came with were nothing like what i could find on these forums.
I know the green one goes into the switch, the big black one goes into the fuse that the kit came with, one of the white ones go into a plug with the blue tape, but i can not figure out where the last white connector and the red goes.
The red one throws me off, i havent seen one of these yet for our foglights.
If anyone has installed these type of fogs, help would be most appreciated, otherwhise i think im going to just splice from my headlights to turn them on.
Tredd is offline   Reply With Quote
Old 04-20-2008, 10:10 PM   #2 (permalink)
Firm approval....I haz it
St Jude
Nomar06's Avatar
have an upclose pic of all the connectors other than the grren one?
The red goes to a power supply. You can tap into one of the empty slots on the fuse box in the car. i believe it is #8 slot.
Black goes to the ground.
This is where I need the pics cause the plug colors you have a diff than what i have seen on a K2 fog kit.
Black(which was blue in the K2 kit) i think goes to the blue empty slot on the top left of the fuse box.
One of the white ones(which was brown) goes to the brown plug that is above the clutch pedal. Grab a flash light.
the other white one stays unplugged.
If you can get pics of the puls I can tell you better which is which.
http://www.8thcivic.com/forums/signaturepics/sigpic6164_17.gif
Nomar06 is offline   Reply With Quote
Old 04-20-2008, 10:17 PM   #3 (permalink)
Chyeaa
Tredd's Avatar
edited for more pix, thanks nomar for the reply put more pix up, so if i understood correct one of the white ones remain unplugged? i know which one goes into the brown one above the clutch pedal, but do u know if the black one goes into the fuse box, where the relay thing ( in the second pic from the bottom) is suppose to go? And also you said the red one goes to the power, but my red cable has that weird connector thing on it (picture 2), do i just take that off and put it into the 8 slot?
Old 04-20-2008, 10:17 PM   #4 (permalink)
sh33t_0f_p4p3r's Avatar
Tobie
thats why i havent gotten ebay fogs cuz they dont hook up like oem ;-(
sh33t_0f_p4p3r is offline   Reply With Quote
Old 04-20-2008, 10:21 PM   #5 (permalink)
Chyeaa
Tredd's Avatar
lol but mine where only 40 bucks and if i were to buy the oem harness, only around $60 total rather than buying the $230+ oem ones that are supposedly prone to crack?
Old 04-20-2008, 10:23 PM   #6 (permalink)
St Jude
Nomar06's Avatar
actually, they pretty much do. Just depends on the kit and if you want them to turn on like OEM.
Old 04-20-2008, 10:25 PM   #7 (permalink)
St Jude
Nomar06's Avatar
thanks for the pics but i honestly think you need to return them and buy a K2 fog kit. i wouldnt splice into my OEM wiring.
The pics u have below the red thing def goes to the plug above the clutch pedal. But still not 100% on the other ones.
Sorry man.
Old 04-20-2008, 10:30 PM   #8 (permalink)
Chyeaa
Tredd's Avatar
thanks for the help though i think, imma try taking off the red thing and putting it into the 8th slot, my dad knows alot about the wiring and stuff and said hes done it to his past cars, so i think i might just let him do the splicing into the headlights, thanks though
Old 04-20-2008, 10:34 PM   #9 (permalink)
St Jude
Nomar06's Avatar
go to collegehillshonda.com and check out the instal intructions for the OEM fogs. Could help some. Thats how i matched up the K2 kit with the stock plugs.
Old 04-20-2008, 10:40 PM   #10 (permalink)
Chyeaa
Tredd's Avatar
yea i tried, sorta got me more confused, haha
Old 04-20-2008, 11:40 PM   #11 (permalink)
vi3tshi3t08's Avatar
this happend to me, nothing seemed to fit..
so i just bought the OEM harness from honda and it hooked stright up to the aftermarket fogs, it was like 40 dollars
vi3tshi3t08 is offline   Reply With Quote
Old 04-20-2008, 11:42 PM   #12 (permalink)
OH MY GOD
im glad im not the only one confused by this. i dunno how to wire anything up on the inside and on top of that, the driverside foglight is rubbing against my filter so i can barely put the bumper back on
ChadwickSoKrazy is offline   Reply With Quote
Old 04-21-2008, 03:11 AM   #13 (permalink)
bLaCkFA5's Avatar
hey thomas i have all the OEM wiring for a SI coupe in my car somewhere, let mek now if you want them case i don't need them
bLaCkFA5 is offline   Reply With Quote
Old 04-21-2008, 03:19 AM   #14 (permalink)
Tracer's Avatar
Tredd, I have no experience with the style of harness you have although it looks similar to the K2 version that I have but w/ different connectors. I suspect that the red connector is supposed to draw the main power from the car and feed it to your fog lights. I have seen that type of connector in the past in other applications and it is a piercing type of connector, its designed to wrap around another wire and the little blades pierce the insulation and make electrical contact inside... known notoriously for causing intermittant connections and failure. You have two choices, you can either find the thick blue wire and try to connect to that or cut the red connector off and tap into a spare slot on your fuse panel (#8 for instance) with a nifty little kit called Add-A-Circuit by Littlefuse. It comes with a bunch of spare fuses, plug the Add-A-Circuit into slot #8 and plug a 10A fuse into the side of it. Also put a fuse in slot #6 as this protects the low current side that flows through the switch and ultimately into the relay.
That spare white connector I suspect probably goes into a slot in the upper left corner of your fuse panel. But that connector won't fit there. Mine was different but I had to cut mine off (actually I pulled the wire and pin out) and stuck it on the lower right pin on the inside of the socket on the upper left corner of the fuse panel. You can test for this by powering up the ignition and using a multimeter and testing for a 'hot' pin.
If you need pics I can supply some for ya... by the way I have an LX Coupe so hopefully its the same style of wiring.
Good luck, hope this helps!
Tracer is offline   Reply With Quote
Old 04-21-2008, 02:08 PM   #15 (permalink)
Chyeaa
Tredd's Avatar
wtf Will? haha yea if you dont need them, might come in handy for me haha. Did you get yours fixed btw?
Old 04-21-2008, 02:11 PM   #16 (permalink)
Chyeaa
Tredd's Avatar
thanks tracer for the reply clarified some things for me.
Old 04-21-2008, 02:47 PM   #17 (permalink)
Chyeaa
Tredd's Avatar
update : i actually got the switch to work so i can turn the switch on, but the problem is that the foglights arent turning on when the switch is turned on. i was thinkin where the foglights themselves connect in the bumper is off, but could it be because one of the plugs on the harness under the dash arent plugged in?
Old 04-21-2008, 11:12 PM   #18 (permalink)
Robstunner's Avatar
Rob
where do u get the oem harness???
(so your saying i can buy Ebay foglights, OEM switch, and OEM harness and that will all work together?)
Robstunner is offline   Reply With Quote
Old 04-22-2008, 02:08 AM   #19 (permalink)
bLaCkFA5's Avatar
yup got them to work. i have the harness connected to the fogs, the oem switch, and the harness under the dash.
the only problem is the one under the steering wheel, i can't get off lol. i attached the relay to its spot and i haven't bothered taking them offf. just let me know whenever you want them
Old 04-22-2008, 02:59 AM   #20 (permalink)
Chyeaa
Tredd's Avatar
so you have an extra set of the set of wires and stuff from the inside will?
foglight trouble vingavina Lighting, H.I.D.'s, & Neon 4 04-09-2008 07:12 PM
Foglight Install Help djthomi Lighting, H.I.D.'s, & Neon 6 04-01-2008 05:22 AM
Ebay foglight install FutureITR Lighting, H.I.D.'s, & Neon 1 12-19-2007 02:15 PM
Trouble with k2 fog install jeremy0203 Lighting, H.I.D.'s, & Neon 6 08-18-2007 10:01 PM
CF hood install trouble hobbvin540 Inside and Out 16 02-08-2007 03:42 PM
