Problem with aftermarket radio & antenna adapter..
So i have an Alpine CDA-9886 headunit installed on my car. I bought this metra antenna adapter
Honda Antenna Adapter Motorola Male to OEM Female at Crutchfield.com but it just doesn't work... i attached the factory radio harness the motorola end adapter and plugged it into the back of the headunit. am i missing anything or doing anything wrong? i can just let the blue wire hang loose right?
#2 (permalink) | |
The blue wire needs to be connected. I had to do this on my Ridgeline. connect it to the +12v power antenna lead on the aftermarket harness. wrong section for this post BTW :P Last edited by jlannoo; 04-20-2008 at 03:18 AM. |
I have a z2 and my fm/am reception is bad so I had a second installer talk a look at my z2 just in case the original installer missed something. Did you use an antenna adapter by any chance? Because I mentioned this the second installers and they told me that newer cars like the civic already has a built in adapter or it can probably to without one. Is he right? Or do I need one? Please help. Thanks.
#10 (permalink) |
Can it technically do without it an antenna adapter? I just want to figure out if it will work without it coz if it can then I know that I don’t have an antenna adapter on mine. But if it can’t work without one then I know that they installed one and the problem is probably caused by something else. Thanks for the help.
| Help Antenna Adapter Question | randylasar | I.C.E., Electrical, Security, & Navigation | 3 | 02-15-2007 01:50 PM |
| Help Quick, Antenna Adapter to Aftermarket | bikinpunk | I.C.E., Electrical, Security, & Navigation | 6 | 06-14-2006 11:47 AM |
| Antenna Adapter | damb | Garage | 1 | 12-10-2005 09:41 AM |
