What exactly are you trying to do? Are you retrofitting these headlights yourself? Are you making the wiring harness yourself?
Home - CustomLightz - The HID Retrofit Specialist Save yourself the trouble. If you don't have any experience or know how things work, do it right the first time. |
Once you get the wire harness planned out the hardest part is soddering the wires together nice and clean. I made 2 wire harnesses for my old ek and the 2nd design worked flawlessly with my oem retrofit. It's really easy. You just need some 12 gauge wire, 1 or 2 relays depending if you want your ballasts on separate electrical systems, some sodder, head shrink tubing, ring connectors, and some conduit wire covers to make it look oem clean. I'm going to begin scouting for parts for my next oem retrofit soon, I suppose I'll post up my info on how to make a wire harness then.
#12 (permalink) | |
CustomLightz
It's pnp for both the single and bixenon setups. One plug for each ballast, and one 9006 plug connecting to the 9006 lowbeam connector. One o-terminal going to the positive of the battery, and another o-terminal going to the negative. THAT"S ALL For the bixenon, ther would be two more plugs which would connect to another plug part of the bixenon solenoid. PANCAKE
Custom Lightz LLC - HID Retrofit Specialist. www.customlightz.com 516-241-9112 Custom Lightz on 8thcivic.com http://www.8thcivic.com/forums/forumdisplay.php?f=150 Custom Lightz: Fog-Light Retrofit http://www.8thcivic.com/forums/custo...rofit-ftw.html
#18 (permalink) | |
![]() Join Date: Sep 2006
I Love Kristina
http://www.8thcivic.com/forums/light...y-harness.html |
#19 (permalink) | |
I looked at customlightz website but their 2nd video of the harness installation is not working |
#20 (permalink) | |
I Love Kristina
| Need help with retros | galaxygraysi | Lighting, H.I.D.'s, & Neon | 3 | 07-26-2007 11:10 PM |
| Yay! Retros = teh sex | SiliconX | Lighting, H.I.D.'s, & Neon | 34 | 07-09-2007 10:48 AM |
