Old 04-11-2008, 05:52 PM   #1 (permalink)
BRSi's Avatar
Hybrid Mirror Turn Signal - Which Bulb???
I am trying to figure out what kind of bulb/led the turn signal mirror takes? I have it on my Si here and trying to make the front/mirror and rear turn signals white like hid color. It is not illegal here. I called Honda there, but they said they only list an entire assembly???
BRSi is offline   Reply With Quote
Old 04-15-2008, 01:13 PM   #2 (permalink)
BRSi's Avatar
Went to the Honda dealer and the stupid housing is sealed. No way to change the bulb and must buy a new housing. Well could probably be heated up, but too much work guess the 2 bulbs/leds will remain orange.
Old 04-16-2008, 02:24 PM   #3 (permalink)
brazilianguy's Avatar
Iuri
i think you would have to open the mirror
brazilianguy is offline   Reply With Quote
Old 04-16-2008, 08:46 PM   #4 (permalink)
BRSi's Avatar
Yes to remove the lens housing you have to open the mirror anyway, but even after opening the mirror, the white/lens housing is completely sealed and there are 2 leds in it. Only way to replace it is getting a new assembly or heating up the assembly (like when you do to clear out headlights).
Old 04-18-2008, 06:54 PM   #5 (permalink)
07_FG_4Dr_S.i.'s Avatar
Jason/NX Junkie
i have directions on how to replace that bulb
did honda tell u you couldnt replace them ?
should i post directions with pix ?
07_FG_4Dr_S.i. is offline   Reply With Quote
Old 04-18-2008, 07:04 PM   #6 (permalink)
Jason/NX Junkie
1 Remove the mirror holder.
2 Remove the cover (A) from the mirror (B).
3 Remove the screw, then pull out the side turn signal light (A).
4 Disconnect the 2P connector (B) from the light.
5 Install in the reverse order of removal.
Old 04-18-2008, 07:06 PM   #7 (permalink)
Jason/NX Junkie
incorrect incorrect and incorrect where did you get all that info ? lol ive done this before but i usually jsut warranty the whole entire setup for the customer saves me time lol
Old 04-18-2008, 11:09 PM   #8 (permalink)
BRSi's Avatar
Well sorry to inform, but you're actually replacing the entire housing and the leds from what I saw are not replaceable. The dealer here showed me the actual housing from a car they were working at (body work). I'll post a picture later that I took from the housing. But if you say I can replace the leds then please let me know how to open the light housing.
Turn Signal Bulb Swap SiConvert887 Lighting, H.I.D.'s, & Neon 6 10-25-2007 09:22 PM
Turn Signal Mirror Modification webby Exterior Style Mods 0 02-22-2006 09:24 PM
