just got new dome light LED and i need help! - 8th Generation Honda Civic Forum
Old 04-09-2008, 12:11 PM   #1 (permalink)
i just got a 9 LED festoon dome light. when i installed it, it was bright, but mainly seemed to all point the light in one direction instead of the factory bulb which distributed light more evenly. superbright leds state that their festoon leds all point in one direction.....how do i distribute the light for better light coverage? buy a different type of bulb?
choestein is offline
Old 04-09-2008, 12:34 PM   #2 (permalink)
use sandpaper to sand the clear plastic part of the LED. until it's not "clear" anymore.
That can help a bit..
icen is offline   Reply With Quote
Old 04-09-2008, 12:41 PM   #3 (permalink)
will that really work? im afraid if anything, that might make the light output weaker?
choestein is offline   Reply With Quote
Old 04-09-2008, 01:53 PM   #4 (permalink)
The total light output will be the same, because the part that generates the light is the semiconductor inside the LED. You are not touching that part.
However, since the light is not "focused" anymore, it might seem less bright.
Think about it this way.
say, there's 100 lumen of light available.
you put 50 lumen here and 50 there, each area gets 50 only
if you focus all 100 lumen on 1 area, that are gets 100 lumen. 100>50, therefore will look brighter.
Old 04-09-2008, 03:27 PM   #5 (permalink)
ok i have the 9 LED bulb that looks like this:
eBay Motors: NEW HID WHITE FESTOON 9 LED BULB 3022 3021 DE3175 (item 350045441966 end time Apr-09-08 15:00:00 PDT)
do i just sand the 9 tips? can u elaborate more on the sanding of it?
Old 04-09-2008, 03:35 PM   #6 (permalink)
wheeler's Avatar
Dave
you could use a dremel with a sanding wheel and file them down that way. I did that for my cup holder LEDs
wheeler is offline   Reply With Quote
Old 04-09-2008, 03:37 PM   #7 (permalink)
file the whole thing so the 9 points are flat?????
Old 04-09-2008, 03:39 PM   #8 (permalink)
wheeler's Avatar
Dave
just take the rounded edges off so they're smooth across the tops
Old 04-09-2008, 03:41 PM   #9 (permalink)
ok so the 9 points that stick out......dont get rid of them, but rather just sand the top part of them right?
Old 04-09-2008, 03:44 PM   #10 (permalink)
wheeler's Avatar
Dave
yeah if you cut them totally off you'd cut them too deep and probably mess up the diode. just that the rounds off the top, polish them a little and you're good to go. takes like 5 minutes. they won't be exactly like your original dome bulbs but definitely defuse the light more. did you consider hooking he dome to the maps for more interior light?
Old 04-09-2008, 03:47 PM   #11 (permalink)
i have an EX, so when i unlock my car or open the door, all 3 lights turn on.....so i guess actually i would rarely use the dome light by itself.....
Old 04-09-2008, 06:39 PM   #12 (permalink)
Sorry , I was at class.
haha maybe you can do ti to the lights that gets turned out frequently =)
Basically, you can sand it as much as you want. the more "dull" the surface is, the better the light can spread.
If you screw up, you can always resurface ti with polish and finner sandpaper.. (lots of work to resurface it tho)
You can also cut out the little "tip" of the LEDs, such that the tip of the LED become a flat surface.. and then sand on the flat surface, that would also spread the lights out. (of course this is irreversible)
What wheeler said is really true!! Even if you stay away from the actualy semiconductor (GaAs diode), there's a really thin wire (either copper or aluminum or gold) that connects the diode to one of the lead of the LED. U might accidentally got to that wire if you cut too deep.
So, only work with the tip. Most of the lights from an LED is focused on that tip anyways.
LED map and dome lights Si 07 Lighting, H.I.D.'s, & Neon 5 03-01-2011 03:09 AM
LED Dome Lights imbossay1028 Lighting, H.I.D.'s, & Neon 12 11-24-2007 02:21 AM
LED dome and map light installed kaungoo Lighting, H.I.D.'s, & Neon 2 12-29-2006 12:12 AM
