Old 04-08-2008, 05:04 PM   #1 (permalink)
SiConvert887's Avatar
Zach
HID Kit help...
Okay, so my fog light of the passenger went out last night and I pulled the bumper off today to check out what the issue could be. Well I open up the fuse relay on my fog light HID kit and look what I found...
Ive already checked every other connection for my headlights/foglights and these are the only two with corrosion. Its definitely water, one of the fuses was still wet (rained like hell yesterday) and it had to be cause the two relays werent tucked away well enough .
I can get these tucked away so this doesnt happen again but does anyone know of a good way to clean these connections, should I run to the store and get some CLR or something like that...? Any help would be much appreciated!
TIA
SiConvert887 is offline   Reply With Quote
Old 04-08-2008, 05:07 PM   #2 (permalink)
SiAzul's Avatar
Mario
I wish I could tell you how to clean them but I do know that theres some kinde of lubricant to avoid moisture getting in there and it doesnt affect the electricity
SiAzul is offline   Reply With Quote
Old 04-08-2008, 05:24 PM   #3 (permalink)
caveman74's Avatar
Kevin
The sell electrical cleaner at autozone.
caveman74 is offline   Reply With Quote
Old 04-08-2008, 05:46 PM   #4 (permalink)
Zach
Yeah thats the general consensus i'm getting is that electrical cleaner and then using some dielectric grease to prevent this from happening again should do it. Thanks for the responses!
question about a HID kit. YoungHoon Lighting, H.I.D.'s, & Neon 11 12-19-2008 11:00 AM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-05-2007 11:36 PM
What you need to know about HID vs HID kit striker_1818 Lighting, H.I.D.'s, & Neon 54 06-28-2007 07:42 AM
