Old 04-07-2008, 03:37 PM   #1 (permalink)
drfters13's Avatar
well i got a problem with my retro
I've had my retro for over a year now with no problems. until last week when the passenger side headlight flickered when i went over a speed bump. then two days later it would go off for couple seconds, and turn back on then off for good. so i popped the hood and checked all the fuses which were all good. but this part that i hooked up the harness to. right between the red and black wire it lights up. when that lights up the bulbs goes off. so when i move it a certain way it stays on so i'm guessing something inside that things isn't touching correctly. blah
drfters13 is offline   Reply With Quote
Old 04-07-2008, 03:45 PM   #2 (permalink)
wheeler's Avatar
Dave
Are you trying to show us something? Maybe a ground issue?
wheeler is offline   Reply With Quote
Old 04-07-2008, 04:14 PM   #3 (permalink)
yoshiod9's Avatar
check your ballast connections. this sounds like the ballast might just be crapping out on you.
yoshiod9 is offline   Reply With Quote
Old 04-07-2008, 05:24 PM   #4 (permalink)
drfters13's Avatar
pictures up
Old 04-07-2008, 06:58 PM   #5 (permalink)
caveman74's Avatar
Kevin
Denso ballast are know for 2 things bad.
1. The clip coming loose and not staying tight
2. Wires inside the silver lining cut and arcing.
I have had a few Denso that arced between the wires. They may have been pinched?
caveman74 is offline   Reply With Quote
Old 04-08-2008, 01:36 AM   #6 (permalink)
striker_1818's Avatar
I Love Kristina
hmmmmm both ballasts? i think i sold you those about a year ago or so. Make sure the connector is tightly secured on the ballast and keep them away from other wires.
striker_1818 is offline   Reply With Quote
Old 04-08-2008, 01:46 AM   #7 (permalink)
Tim
Super Moderator
Tim's Avatar
Last time I had a problem like that, it was a loose connection in my wiring harness.
Tim is offline   Reply With Quote
Old 04-08-2008, 01:55 AM   #8 (permalink)
With mine only one side went out. It ended up being the ground being loose. Try swapping the ballast to the other side to see if it is a ballast problem.
buurrnn is offline   Reply With Quote
Old 04-08-2008, 08:43 AM   #9 (permalink)
NIGHTHAWKSI's Avatar
Ian
i have a problem with denso ballasts. both of them. its not my wiring! (i have other ballasts hooked up to teh same relay harness for about a month now and they work fine)
my denso ballasts turn on warm up, after about 20 seconds, they shut off. one did this and then about a week later the other one did this. its kinda weird that they both do teh exact same thing and around the exact same time. but even when hooked up driectly to the battery they do this. sorry for the threadjack....but any input would help.
and to the OP, i cant see pics at work, but it sounds like you just have a loose connection somwhere. your saying you slightly move the wires and it works fine....just find a way to keep the wires in that position.
Old 04-08-2008, 01:48 PM   #10 (permalink)
drfters13's Avatar
yea i moved that thing that plug so where it doesnt move as much and its working fine. its that plug not the ballast. when it moves around it turns off the light. and when it turns the light off, it lights a orange redish thing in the plug. could that be a hazard?
Old 04-08-2008, 01:50 PM   #11 (permalink)
Ian
what plug? the ignitor that connects to the bulb? or where it plugs into the ballast?
either way, wires glowing red/orange is not a good thing.
Old 04-08-2008, 10:18 PM   #12 (permalink)
drfters13's Avatar
the one from the harness connecting to the 9006 plug i think. the one in the picture.
retro ? NcSi Lighting, H.I.D.'s, & Neon 37 03-12-2008 11:45 PM
retro problem timmytimtimm Lighting, H.I.D.'s, & Neon 25 10-27-2007 04:16 PM
Another RETRO 4 ME jrMartinez24 Lighting, H.I.D.'s, & Neon 33 07-19-2007 03:03 PM
If I were retro.... si_civic Lighting, H.I.D.'s, & Neon 11 07-19-2007 01:27 PM
Looking for Someone to do a Retro for me Audirs4 Lighting, H.I.D.'s, & Neon 1 04-12-2007 10:23 AM
