Old 04-07-2008, 11:20 AM   #1 (permalink)
HID Problems !?!?
So I just got a 2008 Civic Si last Friday. That same night I installed a set of 12K Xenon HID's. Now they worked fine until 20min after having them on. the passenger side bulb went out. i checked my fuse and it was blown. i replaced it again with another 10. it worked until saterday night and it blew it again. only the passenger side bulb not the driver side. so i once again replaced it but put 15 in it. and it blew it right off the bat. so i was F*ck it. put a 20 in. they worked fine and 5min later. both blew out. now I checked the fuses and they are intact. i put a set of stock 10's back in and nothing. lights are GONE. any idea's ? at this point im just curious i went and bought a set of PIAA's Performance bulbs. no HID BS anymore. havent installed them yet so hopfully i didnt f*ck anything up internally. i checked for melted wires or any wire being cut and touching something. but nothing. any idea's ? if you all say xenondepot is good then ill take these 90 dollar regular bulbs back and purchase an HID kit. the thing with my current HID kit. there is not extra ground cable that comes with it. it just plugs the stock plug into the ballist and then from that the HID bulb. help.
sorry to post twice. just not sure if anyone will go and read the other post.
TripleJ07 is offline   Reply With Quote
Old 04-07-2008, 11:25 AM   #2 (permalink)
NIGHTHAWKSI's Avatar
Ian
did you install a relay harness?
if not, get one. that will fix it.
if your blowing a fuse in your relay harness, bump it up to a 20 amp fuse.
DO NOT increase the amps of an OEM fuse!!! put it back to stock.
search for relay harness and you should find a schematic to make one.
Old 04-07-2008, 11:34 AM   #3 (permalink)
no relay harness.... does xenon depo's kit come with one?
Old 04-07-2008, 12:10 PM   #4 (permalink)
xenon depot's hid kits have the relay harness.
Probably your passenger side HID igniter has some sort of defect in it.
Causing it to draw excess current, and brunt the fuse...
thenu put in a 20A fuse, something else got burnt.
icen is offline   Reply With Quote
Old 04-07-2008, 05:06 PM   #5 (permalink)
yeah it burnt the fuse under the hood. i took it in to honda and they took care of it for free. i put those PIAA's in but they dont look that great compared to HID's.... I think im addicted
HID problems in cold weather Rach Lighting, H.I.D.'s, & Neon 24 01-19-2009 05:25 PM
HID problems lilchoi26 Lighting, H.I.D.'s, & Neon 13 10-24-2007 03:03 AM
HID problems. Help please. FBP FG2 Lighting, H.I.D.'s, & Neon 5 09-22-2007 11:48 PM
HID fog problems Vi3t DrAgOn 714 Lighting, H.I.D.'s, & Neon 4 06-17-2007 06:56 PM
HID problems ccvic Lighting, H.I.D.'s, & Neon 5 06-12-2007 10:36 PM
