Old 04-03-2008, 07:57 PM   #1 (permalink)
tuner student's Avatar
Location: stationed in Newburgh NY/ born and raised in orlando, fl
Andrew
tiny interior light question
I used a DIY for lighting the floor boards and cup holders from this site (forgot who did it) as a guide when i did my car. The person took LEDs and used a dremal to sand the lights flat to spread the light and get rid of the dots. well (due to what i had to work with) i have LEDs that are in a plastic dome to light the floor boards. they spread the light well but creat an egg like shape light instead of red dots. my question is if i used sand paper and scuff up the domes real well do u think it will spread the light? or is there some easy way to fix this?
tuner student is offline   Reply With Quote
Old 04-03-2008, 08:42 PM   #2 (permalink)
Aastan's Avatar
Aastan
Yes it will.
Aastan is offline   Reply With Quote
Old 04-03-2008, 08:51 PM   #3 (permalink)
Adrian
Scratching / cutting the plastic will create more facets for the light to reflect off of.
So it will create a larger dispursion pattern.
so.. yes it will.
Cr8tive_leo is offline   Reply With Quote
Old 04-03-2008, 11:17 PM   #4 (permalink)
Andrew
sweet any clue of about how much i need to scuff it up. i no its hard to tell/describe but just wondering. i don't want to diminish the brightness that much hopefully
Old 04-04-2008, 08:54 AM   #5 (permalink)
Adrian
You can use aluminum foil too to make a 'light shade' , even though most leds are directional, (light goes where it's pointed) you can reflect the light too by adding some reflective materials. Aluminum foil is awesome for that.
Try it, experiment. take the led, wrap half with almunium foil, and another one without, see how they compare. It may be what you are looking for.
If you cut the led with a dremel you will get better reults then with just sanding.
Sanding will cover the surface with micro cuts, you might want to just scuff the top of the led, the 'bulge' so the light is dispersed there, but the sides are clear and radiate normally.
interior light 1255 Civic SI 9 01-02-2008 11:30 PM
EX to SI interior light conversion? kx_rider53 I.C.E., Electrical, Security, & Navigation 7 11-20-2007 06:06 PM
Trunk light LED solution!!!! MUST SEE!!! its soo tiny! tda1337 Lighting, H.I.D.'s, & Neon 4 11-12-2007 09:50 PM
Little blue interior light viffer Civic Coupe And Sedan 21 01-26-2007 12:39 AM
Interior Ambient Light Flyboyflash7 Lighting, H.I.D.'s, & Neon 12 12-17-2006 10:18 PM
