IM looking for the right bulb to replace the drl's... - 8th Generation Honda Civic Forum
Old 03-28-2008, 05:17 PM   #1 (permalink)
06bklcivicsi's Avatar
E
Hey Guys I did the search but no luck.... Anyways, Ive seen acouple of pics of guys on here that have yellow light bulbs in the conpartment for the drl's/high beam... Im looking for something similar since im planing to purchase the yellow fogs pretty soon and wanted them to match...
Does anyone know the size and maybe where to purchase them? I want good quality and not cheap looking when on.....
Thanks
06bklcivicsi is offline
Old 03-28-2008, 05:25 PM   #2 (permalink)
boysk8er88's Avatar
travis
HID? 3000k
boysk8er88 is offline   Reply With Quote
Old 03-28-2008, 11:46 PM   #3 (permalink)
cdubb77's Avatar
Carl A. White
Thanks
Got mine below on Ebay.
cdubb77 is offline   Reply With Quote
Old 03-29-2008, 03:01 AM   #4 (permalink)
cambodianricer's Avatar
JLee
is there two bulbs or one???
cambodianricer is offline   Reply With Quote
Old 03-29-2008, 12:01 PM   #5 (permalink)
djdisturbed's Avatar
Chris "DJ Disturbed"
I'm the exact opposite... I want to find some lamps that will make my DRL's NOT yellow. What lamps will make them look like a dimmer version of the white lights. Right now i'm running Silverstar Ultra in the low beams.. but plan on getting HIR's when i get the chance (at least till i can afford to get a Projector Retro done)
djdisturbed is offline   Reply With Quote
Old 03-29-2008, 08:35 PM   #6 (permalink)
Stein's Avatar
The highbeam is a 9005 and you can get them from many different companies. I have PIAA and they are very nice.
Stein is offline   Reply With Quote
Old 03-29-2008, 10:20 PM   #7 (permalink)
Coastale's Avatar
I wish they had a nice cluster of 1 watt white LEDs for the 9005 bulb type. I'd be fine having those as my DRLs (I'm mostly in the city/well lit areas).
Coastale is offline   Reply With Quote
Old 03-30-2008, 03:16 AM   #8 (permalink)
SiConvert887's Avatar
Zach
I think a company called VLED makes 9005 LED bulbs, afaik those would work as DRLs..
SiConvert887 is offline   Reply With Quote
Old 03-30-2008, 09:08 AM   #9 (permalink)
brdhouse's Avatar
Bill
Here you go: eBay Motors: PIAA TERA 6000K White LED 9005 9006 HB3 HB4 Fog DRL NEW (item 370037360736 end time Apr-04-08 17:49:51 PDT)
Not sure if they would work, and you would likely be killing the functionality of your high beams... probably illegal as well, but hey, they're 9005 LEDs! w00t!
brdhouse is offline   Reply With Quote
Old 03-30-2008, 06:54 PM   #10 (permalink)
08taffetawhite's Avatar
just buy 9005 brights...... they will fit
08taffetawhite is offline   Reply With Quote
Old 04-02-2008, 04:56 PM   #11 (permalink)
E
Kool thanks guys for all the feedback
06bklcivicsi is offline   Reply With Quote
Old 04-02-2008, 06:10 PM   #12 (permalink)
grrrrr.... tried the hyperwhites in mine to make the DRL's look more white then yellow and that still didn't do it... so i just said the hell with it and pulled #37 fuse....
Old 05-10-2008, 05:06 PM   #13 (permalink)
Coastale's Avatar
That's why I was looking to go LED. Any filament based bulb will have a lower (yellower/orangey) color temperature when at a dimmer amount of power going to the bulb. Unless you had a crazy amount of blue on the bulb, the DRL will look yellow. If I knew more about electronics/soldering, I'd mount a 3 watt white led surrounded by white 1 watters on a 9005 base and have me a nice little DRL bulb.
9005 bulb = HB3 bulb? AznSupastar Lighting, H.I.D.'s, & Neon 3 12-01-2011 01:26 AM
I need to replace a bulb Lit06Si Lighting, H.I.D.'s, & Neon 10 06-18-2008 09:29 PM
DIY: 3W LED festoon bulb and trunk bulb creation (in progress) tda1337 Lighting, H.I.D.'s, & Neon 1 04-16-2008 11:10 PM
which is the bulb for the brake light? need to replace. kuad Mechanical Problems & Technical Chat 0 01-17-2008 02:33 PM
DRL's riceracr99 Lighting, H.I.D.'s, & Neon 31 02-03-2006 12:25 PM
