07 G35 Projectors - Opinions//Advices Needed - 8th Generation Honda Civic Forum
Old 01-26-2008, 05:13 AM   #1 (permalink)
tin
Having the urge to get retro fits for my 07 civic ex coupe, my friend is selling his G35 projectors. Of which, i'm not really sure if i should get it or not, so opinions about these?
mmmTIN is offline
Old 01-26-2008, 05:21 AM   #2 (permalink)
as far as i know they are pretty similar to FX35 projectors and arent bad. Striker_1818 and sponsor -Bionic- know a lot more about HIDs and projectors than I do and will probably chime in here when they see the thread. I would also suggest checking out HIDPlanet.com for more info about the projectors.
ethlar is online now   Reply With Quote
Old 01-26-2008, 01:20 PM   #3 (permalink)
striker_1818's Avatar
Christian
stock G35 has more intensity than the stock fx35. But fx35 has more width overall. Swap some tsx/e30 lenses and you're good to go.
striker_1818 is offline   Reply With Quote
Old 01-26-2008, 05:49 PM   #4 (permalink)
tin
don't know much about swapping lens, how hard are they to install//price?
mmmTIN is offline   Reply With Quote
Old 01-26-2008, 05:55 PM   #5 (permalink)
8thcivic Sponsor
strutking's Avatar
its pretty much just labor, $$$$
http://www.strutking.com
FREE Shipping within the US!
strutking is offline   Reply With Quote
Old 01-27-2008, 04:30 AM   #6 (permalink)
I don't think swapping the lens is the hard part, I think actually finding a pair of TSX lenses without having to buy the entire set of projectors is the harder part. You can always wrap the TSX lens up in tissue paper and mail it with a set of G35 projectors and have Bjorn (aka -Bionic-) do the swap for you. Good luck though. Try HIDPlanet.com or eBay.com for deals on TSX lenses/projectors. I had much success with my FX Projector/TSX Lens setup.
eXTCspeed is offline   Reply With Quote
Old 01-27-2008, 06:16 AM   #7 (permalink)
Christian
ebay will be your best friend. Getting the lenses holder is the hardest thing. It is a pain in the ass to do it without ruining the lenses holder
Old 01-27-2008, 07:59 AM   #8 (permalink)
tin
sorry about being a noob at these things, but whats the benefits of these pricey tsx lens?
Old 01-27-2008, 12:19 PM   #9 (permalink)
divinebarrel's Avatar
Nathan
a nice clean cut off line. retros are pricey its best to use quality parts
divinebarrel is offline   Reply With Quote
Old 01-27-2008, 01:08 PM   #10 (permalink)
"Pricey" TSX lens? Well, the stock FX/G projectors are fine by themselves. In stock form they offer pretty good cutoff, are bi-xenon, and fit fine in the 8thcivic housing. On the other hand, you can choose to find a pair of TSX lens and swap them in. I believe doing this will produce a sharper cutoff and more blue/purple color at the cutoff as well. In my opinion, TSX are the best bang for the buck, but if you want to go bi-xenon, then a FX projector with a TSX lens swapped in works pretty well. TSX projectors/lens aren't as expensive as say, a S2000 projector, which is double the price, but the S2000 projectors offer a sharper cutoff and more width.
Old 01-27-2008, 09:30 PM   #11 (permalink)
Christian
A clear lense swap will yield a whole lot more output than the fresnel/foggy lense that they come with stock. Aside from that, you will get a sharper cutoff with more blue.
In other words, with a clear lense swap, you get more output and a sharper cutoff.
Old 01-28-2008, 01:00 PM   #12 (permalink)
firstsi's Avatar
i helped another member do his and the projectors are really big and we couldnt get them into the headlight enough to get the rings on
secondly the adaptive ones have big holes in the body where the motors were, and we used alot of fiberglass to get them weather proof
he is really happy with the out come tho
good luck
The fx35 projector DiY aftermath and looks Mad props to Firstsi
firstsi is offline   Reply With Quote
Old 01-28-2008, 01:54 PM   #13 (permalink)
Christian
good luck
I ran into the same problem with the fx until i knew that by cutting the top part of the projector, output is not molested. So, after cutting the top notch, it fits good.
G35 projectors are different.
These are what these look like. g35 on the far right and right behind it is an fx35. Sorry for not having a better picture but i got rid of those projectors a long time ago.
Old 02-07-2008, 01:49 AM   #14 (permalink)
clintdaniels's Avatar
Clinton
If they are bi-xenon, that means that the projectors affect high and low beam, is that right? If so, what happens to the bulb in the stock headlamps that are DRL/High beams if the bi-xenon projector now performs the duties of both low and high beams?
Thank you for any enlightenment!
clintdaniels is offline   Reply With Quote
Okay so opinions needed please slostjoe Bolt-Ons And All-Motor 7 06-05-2007 10:21 PM
opinions needed civix Wheel And Tire Upgrades 0 05-07-2007 09:42 PM
Opinions Needed!!! mfinlay04 Introduction & Pictures 15 04-08-2007 04:37 PM
Opinions Needed... Lordnikon0612 Wheel And Tire Upgrades 21 12-22-2006 03:29 AM
Opinions needed... Caper Wheel And Tire Upgrades 8 12-07-2006 08:34 AM
