Old 05-08-2006, 11:04 PM   #1 (permalink)
HIDs and Aiming the Light?
I hope this hasn't been covered yet... if it has my bad
Anyway, so the headlights for our civs have adjustable aim by turning something underneath the headlight? Will this fix problems of blinding people in oncoming traffic if you install aftermarket HIDs?
taejinah is offline   Reply With Quote
Old 05-09-2006, 10:52 AM   #2 (permalink)
there are two crown gears per headlight to adjust up/down and left/right. Look around the headlight area under the hood and you will find the locations. You will need a long philips to adjust them
Tate is offline   Reply With Quote
Old 05-09-2006, 11:03 AM   #3 (permalink)
Mini Me!
Cybergypsy's Avatar
cool...thanks for theinfo
Old 05-11-2006, 11:47 PM   #4 (permalink)
I have not been able to find the crown screw that allows me to adjust left/right.
I had the front bumper off 3 times now and every time I had it off I looked around for any adjustment point but still nothing. Am I not seeing it?
Up and down is the easy one to find.
Fresh-Popcorn is offline   Reply With Quote
Old 05-12-2006, 12:02 AM   #5 (permalink)
there is no left right adjustment... only up and down...
XeNonCiViC is offline   Reply With Quote
Old 05-14-2006, 03:39 AM   #6 (permalink)
el_ben2's Avatar
i already have HID aimed by the dealer... but i think its too low, ill try to aimed again and then ill hit the road
if someone shows me his middle finger, its the sign that its ok
lol
el_ben2 is offline   Reply With Quote
Old 05-14-2006, 11:21 AM   #7 (permalink)
Tim
Super Moderator
Tim's Avatar
There are practical ways for aiming headlights rather than the middle finger approach.
Tim is offline   Reply With Quote
Old 05-15-2006, 11:50 AM   #8 (permalink)
Type X's Avatar
yup
Type X is offline   Reply With Quote
Old 05-22-2006, 02:54 PM   #9 (permalink)
joonoo's Avatar
David
One word, nope. Any aftermarket HID put inside stock halogen housing will cause glare unless of course you aim it down so much that you can't see anything at all. Anything in range of stock position will glare oncoming traffic.
lol
Please don't do that... I do lot of nighttime driving now days and my eyes are tired as hell due to people with aftermarket HIDs and poorly aimed headlight. If you combine it both.. I might as well just swerve into you or something
I'm just playing, but seriuosly take another approach. Parking your car about 25ft froma wall on leveled ground Your cut-off point (if you still got any... it's not the glare that HID makes..) should be about 4" below level of your headlight. Basically measure ground->headlight - 4" = ground to your cut-off at 25ft.
joonoo is offline   Reply With Quote
Old 05-28-2006, 07:22 PM   #10 (permalink)
MaKo's Avatar
I will be using this guide to help in aiming mine when my retro is done. I opted for the reflectors though. Can't see HID being of much value in the halogen housing.
http://faqlight.carpassion.info/hl-aiming.htm
MaKo is offline   Reply With Quote
Old 05-29-2006, 12:55 AM   #11 (permalink)
Tim
Super Moderator
Tim's Avatar
I think you meant to say projectors.
In a lowered car, it could be possible to aim the lights so that your light is straight across or only slightly lower at 25 feet. This will give you some viewing distance and it won't be offensive to the eyes of oncoming traffic.
Old 05-29-2006, 03:39 AM   #12 (permalink)
MaKo's Avatar
Yep, sure did.
Old 11-16-2006, 10:45 PM   #13 (permalink)
trixnrice's Avatar
wait. WHERE exactly is the up/down aiming screw on the headlight?!??!?!?!
trixnrice is offline   Reply With Quote
Old 11-21-2006, 07:11 PM   #14 (permalink)
HRPFG2's Avatar
Tom
So what you are saying is if your car is lowered and you use HID in the factory housing you shouldn't blind any one?
HRPFG2 is offline   Reply With Quote
Old 12-01-2006, 09:35 PM   #15 (permalink)
Danny
YEAH!!!! what he said!
Menez is offline   Reply With Quote
Old 12-01-2006, 09:41 PM   #16 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Well you'll still be blinding other lowered cars, if that's what he meant.
Old 12-01-2006, 09:43 PM   #17 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Pop open your hood and you will see a hole on top of each headlight on the black plastic cover that's over the radiator. You will see next to the hole a directional arrow with U for up and D for down. You can either use a long screwdriver to adjust your headlights up and down or some have said you can also use a socket wrench on the side of it.
Old 12-02-2006, 04:51 PM   #18 (permalink)
Danny
can someoen please post a picture so that i can see for myself pleaseeeeeeeeeeeeee.
Old 12-02-2006, 10:12 PM   #19 (permalink)
lol
AHHAHAAHHAA
freekaingjon is offline   Reply With Quote
