HID Info - 8th Generation Honda Civic Forum
Old 12-12-2007, 12:05 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Mr.Tafetta's Avatar
HID Info
Hey guys
So i seek the help of the all knowing Civic pros. I am planning to get an HID kit. I am however in the dark on this subject, and do not know a darned thing.
Would you guys be able to help me with some information.
I have questions such as, do i need projector headlights to run HID's? If i dont, will it be good enough? Whats a good color temperature to get? Questions such as those.
Im sorry these questions may sound newbish, but in actuality they are
Also i keep seeing adds for HID kits for 140 when you go to the home of 8thcivic:
www.autoxsport.com Your #1 Source for Xenon HID Conversion Kit AUTO & MOTORCYCLE
Whats your guys' opinion on these?
so all in all i guess what i am asking is what in the hell do i need to get HID's in my car so i can see the gosh darn road better!
Thanks!!
mr.tafetta
Mr.Tafetta is offline
Old 12-12-2007, 12:18 AM   #2 (permalink)
wing_gundam's Avatar
Civic Type Stock
Hey, you don't need projectors. Basically you can replace the 9006 halogen bulbs with HID bulbs. 9006 is the lowbeam one. The brightest ones are 4300k (kelvin) and go higher. However, the higher you go the weirder the color goes and you lose brightness. There isn't much point going past 6000K - pale blue/white unless you want to just use your lights for show.
I crack nuts for a living
wing_gundam is offline   Reply With Quote
Old 12-12-2007, 12:20 AM   #3 (permalink)
Civic Type Stock
Moved to lighting forum
Old 12-12-2007, 02:24 AM   #4 (permalink)
Mr.Tafetta's Avatar
Thanks so much!!!
that cleared up some things for me!
now another question:
what do you think of the ones in the link that i had posted?
Are they good? are they bad? love em hate em? opinions?
Thank you so much, i feel like a mooch asking for so much information!
mr.tafetta
Mr.Tafetta is offline   Reply With Quote
Old 12-13-2007, 03:46 AM   #5 (permalink)
Mr.Tafetta's Avatar
bump for a lil bit more info! plzzz
Old 12-15-2007, 07:38 PM   #6 (permalink)
J_Bone's Avatar
I thought I read that you just couldn't put in HID bulbs?
How about that HID kit? www.autoxsport.com Your #1 Source for Xenon HID Conversion Kit AUTO & MOTORCYCLE
Anyone try this?
J_Bone is offline   Reply With Quote
Old 12-16-2007, 05:59 AM   #7 (permalink)
Mr.Tafetta's Avatar
yah well thats the one i was asking about as well...
Well you can put in the whole HID kit, nad they can go in to reflector headlamps, from what i was told by wing_gundam.
Im really curious about the HID kit that J_bone and i were wondering about...
info plz!?
Old 12-26-2007, 12:30 AM   #8 (permalink)
Vince
there are 2 basic hid types that one can choose.
1- plug n play kits- you have a ballast, ignitors, wiring, and bulbs that fit in your stock reflector housing
2- retrofit- this is the more expensive. more sickkkkk brighter, better cutoff, wider beam pattern ones.
the plug n play kit uses your stock housing and just puts in a really bright bulb.
pros- better than stock light output, cost less, easy to install
cons- crap cutoff, narrow beam pattern, potential to blind oncomming traffic
the retrofit uses a projector from another car (tsx, s2000, lexus, audi, etc etc). and they drill the projector to fit into the stock headlight housing.
pros- super great cutoff, wide beam pattern, super great driving, looks super wickeddd
cons- more expensive, you might mess up
lights..
4000k is yellow, 6000k is whitish, 8000k enters blue, 10,000k is entering purple.
higher the number, greater the temperature, less the light output.
vincentek9 is offline   Reply With Quote
Old 01-17-2008, 02:32 PM   #9 (permalink)
imdanchu's Avatar
Originally Posted by vincentek9 View Post
lights..
sorry to correct you on this one, but 4100k-4300k is pure daylight brightness which = best light output. when you get under 4000k, like 300k for example, thats when it gets yellow. 6000k is a light hint of blue, and then you are correct from 8000k and on.
not trying to be rude, but just trying to put correct information out for everyone. i have an HID kit installed on mine thats 4300K and it really does look like daylight at night. auto manufacturers that include HIDs for their cars use only 4100K - 4300K if i remember correctly due to safety and function reasons. Its only their projectors that make it seem bluish when you see them. i hear going up to 6000K should be the furthest you stray from 4300K if you do want the hint of blue.
the further you go from 4300K, the worse the output lighting gets. don't get me wrong, they will still be bright and the hotspot will be dense with light, but the light around the hotspot will be much much weaker. in this case, if its a dark wet night, you wont be any better off than you were with the halogens.
hope this helps!
imdanchu is offline   Reply With Quote
Old 01-21-2008, 02:29 PM   #10 (permalink)
da_lsvtak's Avatar
is it my understanding that the FA5 uses a 9006 harness?
da_lsvtak is offline   Reply With Quote
Old 01-21-2008, 02:49 PM   #11 (permalink)
xvoltm2's Avatar
Mick
My Civics HID DIY Installation
under $140 shipped, good quality and come with warranty
xvoltm2 is online now   Reply With Quote
Old 01-21-2008, 09:34 PM   #12 (permalink)
PSU Pinoy PSU's Avatar
Eric
subscribed
PSU Pinoy PSU is offline   Reply With Quote
Old 01-26-2008, 01:29 AM   #13 (permalink)
gus738's Avatar
so what do people think of that website the op posted?
gus738 is offline   Reply With Quote
Old 01-26-2008, 02:04 AM   #14 (permalink)
Andy
i have the 6000k, i love em.
probably get the 3000k for my fogs...
but i bought my HIDs off craigslist for 160 i believe? (pnp btw)
infinite0216 is offline   Reply With Quote
Old 01-29-2008, 11:27 PM   #15 (permalink)
i have a question i have a the mccullock hid kit its 10000K but i wanted 8000 can i just replace the bulbs to 8000 or i have to replace the whole ballast and everything?
galaxygraysi is offline   Reply With Quote
Old 02-11-2008, 11:27 AM   #16 (permalink)
i like the Xentronix HID kits...their Digital unlike a lot of other HID kits around...they'll never flicker and wont turn off on one side...and the ballast are the smallest ballast in the world...
*~ HID's ligths and Bulbs ~* - Houston-Imports.com
CiViC_Si_4_ShO is offline   Reply With Quote
Old 02-11-2008, 10:32 PM   #17 (permalink)
propz
daowizmm is offline   Reply With Quote
Old 02-22-2008, 03:37 PM   #18 (permalink)
SiAzul's Avatar
Mario
I see youve had them for a while now, I wanna order some and just want to know if youve had any issues with them? I believe theyre going for $120 shipped now
SiAzul is offline   Reply With Quote
Old 02-22-2008, 03:41 PM   #19 (permalink)
SiAzul's Avatar
Mario
also what store did you get that tack puller? I cant find one
Sorry for the thread jack
Old 04-15-2008, 04:04 PM   #20 (permalink)
ive heard that either TSX or TL ((cant rememebr which)) headlights will fit.. is that true ?
calibroha is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/69015-hid-info.html
8th Generation Honda Civic Forum This thread Refback 12-12-2007 12:11 AM
My Civics HID DIY Installation Orient Express Lighting, H.I.D.'s, & Neon 1660 01-25-2012 12:12 PM
KAIXEN HID Kit Installation DIY! Excelerate Lighting 59 10-13-2011 05:16 PM
What you need to know about HID vs HID kit striker_1818 Lighting, H.I.D.'s, & Neon 54 06-28-2007 08:42 AM
Info on this HID Kit FlyJigga Lighting, H.I.D.'s, & Neon 10 05-08-2007 09:58 PM
Info about HID Conversions JapTrapLove Lighting, H.I.D.'s, & Neon 20 03-28-2007 10:13 PM
