fog light question
just want to make sure I do ir right:
these picture are for my realy harness, can you tell me where to plug these wires: http://img.photobucket.com/albums/v2...Picture072.jpg also about th fog light templates what's the use of the 10mm you do in the bumper?? |
Thats Mr.Bart to you!
sorry man but i didnt get my foglights in yet, but the ring terminal looks like is a ground and im not sure about the spade terminals...
Who is your kit by? k2, ebay(automicstreet) or oem??? have you tried this??? DIY: Install guide for OEM fogs... looks like that might link the right to the left??? |
![]() Join Date: Sep 2006
I Love Kristina
red with a terminal is positive,
black with a terminal is your common ground so you ground it anywhere in the chassis/metal. The two spade connectors coming out of the thick black wire goes to your 9006/h11 stock harness. |
#9 (permalink) | |
I Love Kristina
#11 (permalink) |
I am using the harness so that I have it plug to my battery.
can ayone tell me where to plug the 2 spades connector?? is it to the brow 2 pin connector behind the rad tank?? can ayone tell me if i am missing a harness this is my switch harness: http://img.photobucket.com/albums/v2...Picture074.jpg Am I suppose to have more then two harness?? I only had a harness to plug the fog and the switch harness. |
#13 (permalink) | |
I Love Kristina
#18 (permalink) |
yeah I follow diy install fog but it's not the same wire at all and try to follow the honda instruction it's different also. I went to A place where they install fog and the guy coudn't figure it out. If I plug the two spade thing to the brown single wire behind the reservoir how my fog are gonna work? are they gonna be always on?? If Im able to work the switch thing can you turn the fog whenever you want or they come one when you have you're low beams on???
the guy who install my fog plug them directly with my low beam so whenever I turn my low beam on the fog come on and when I turn my hig beam on the fog still stay on. So it's fog+low beam+high beam at the same time, is tihs gonna drain too much power??? because pretty soon i'll have my retrofit headlight so it would be s2000 low beam+es300 hid fog+ hir headlight. is it bad to have them all on at the same time? |
| Fog Light Switch Harness | mrk | Lighting, H.I.D.'s, & Neon | 0 | 08-05-2007 04:30 AM |
| Fog Light ??? | miles10238 | Lighting, H.I.D.'s, & Neon | 4 | 08-02-2007 12:20 AM |
| yellow fog question | 06silvercivic | Lighting, H.I.D.'s, & Neon | 6 | 04-24-2007 06:28 PM |
| Cracked Fog Light | WaterCop | Lighting, H.I.D.'s, & Neon | 2 | 12-04-2006 06:52 PM |
| Fog light switch direction | dentrecords | Do It Yourself Articles | 7 | 11-28-2006 01:05 AM |
