FA5 LED Switchback Issues - 8th Generation Honda Civic Forum
Old 10-11-2016, 11:45 AM   #1 (permalink)
Mourtzy just put it into 1st gear on 8thcivic
Hey all,
My apologies if this has been answered already but I've searched for hours and haven't been able to find a concrete solution.
I installed LED Switchback signals in my FA5 the other day (1157 bulb type) - they are the Amber/off type which means that the white actually turns off when the signal flashes. I prefer that look over Amber/white/amber.
I'd already wired up load resistors to the signals to prevent hyper flash, etc.
And when I turned on the parking lights after installation, both of the LED's died almost right away, and blew my #15 fuse.
The bulbs are dead and I'll be replacing them today. I changed the fuse and returned everything to normal (stock turn signals) and now everything is fine again.
If anyone has any advice for this issue I would greatly appreciate it - and specifically for the Sedan, as I believe that the signals for the Coupe are a different bulb type.
Thanks in advance,
- Josh
Mourtzy is offline
Old 10-11-2016, 12:17 PM   #2 (permalink)
Skavenger's Avatar
John
Skavenger just put it into 1st gear on 8thcivic
Did you try them without the resistors before they blew up? I've never had a led burnout on me but I haven't ever used resistors either.
Skavenger is offline   Reply With Quote Quick reply to this message
Old 10-11-2016, 01:01 PM   #3 (permalink)
No I didn't. However, I did test the resistors out to make sure they were wired properly.
The way I did this was disconnect the signal, and then turn on my signal from inside the car.
If the resistor is connected properly, the car won't hyper flash. If it's not, then it will detect that a bulb is out.
Maybe it's worth trying without the resistor wired up....
Although I can't stand hyper flashing lol so in essence this wouldn't really fix the problem unfortunately.
Mourtzy is offline   Reply With Quote Quick reply to this message
Old 10-11-2016, 02:41 PM   #4 (permalink)
Skavenger's Avatar
John
Right, I was just thinking that it could possibly help sort out the issue whether it was the bulbs or the resistor. I guess doing that could cost you another set of bulbs and I know switchbacks aren't the cheapest.
Old 10-11-2016, 03:17 PM   #5 (permalink)
Yeah that makes total sense.
A plus in this situation is that I purchased these bulbs locally, and I'll be getting them replaced for free under warranty.
So I'm going to drop by the store today, and try again without the resistor right at the store and see what happens.
I appreciate the help. I'll have to keep you posted.
Old 11-11-2016, 11:59 AM   #6 (permalink)
Not sure how many are still curious about this. But it turns out that certain switch-backs weren't working with my car. Both with and without the resistor.
These specific switch-backs were quite high tech and I'm thinking that maybe the logic boards within them were causing some of the problems.
I exchanged them for simple, bight Amber LED signals (same brand) and they work great. No issues whatsoever...
So although I didn't find the issue, I hope that this post will help some people out.
Cheers
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
My journey to build the ultimate daily driver // 2008 FA5 upperright18 Car Builds 68 03-07-2017 11:36 PM
💡 [NEW] Xtreme LED Headlight & Fog Light Kits 💡 XenonDepot Lighting, H.I.D.'s, & Neon 16 01-17-2017 02:36 PM
Starting issues donotdisturb720 Mechanical Problems & Technical Chat 8 11-19-2016 11:03 PM
I've read for weeks. 100s of pages. Race Suspension for FA5 ;-) hondrta Suspension and Brakes 9 09-28-2016 04:25 PM
