#181 (permalink) |
If you really want to get some use out of your HIDs, use them as your brights :P
This is a 55w (5x brighter than halogens) 6000k PnP kit off ebay as the high beams with factory halogen low beams (these are not before and after shots, they're low beam/high beam shots): ![]() ![]() ![]() ![]() Here's a video of them warming up (the lights get dimmer after the HIDs fully warm up due to the camera's auto brightness feature) : Video of brights - Photobucket - Video and Image Hosting |
#184 (permalink) | ||
#188 (permalink) |
Ok, so i've been reading a lot of these threads lately and i'm very confused about this whole HID thing. Now, I want to know how many people are using PnP kits in their stock civic reflector housing and are they "blinding people". I know that with a good projector setup like TSX or s2000 the cutoff with be much much beter but also very expensive. So I just wanted to know if it is "good" to just use a PnP in a stock 8th gen civic reflector housing?
#191 (permalink) |
Jew Crew
you prob arent grounded properly
![]() ^^clicky DIY HFP Front Lip Overlay CHEAP! | DIY HFP Side Skirt installation DIY AUTO Shift knob Removal | DIY E-Brake Trim removal | DIY Breakfast Pizza |
#193 (permalink) |
Mine also a pnp and when I turn on, I didn't hear any static or click coming from the speakers but it starts out bright in less than a second and it dimms and then starts to heat up to a superbright and down to a little dimmer after the lights did one flick and it stays that way. Is it normal or like that? It doesn't bother me, but I just don't want to fry my harnesses. Any comments?
If its the grounding, I attached the plate holder directly to the body of the car. If its not enough, how to find/make a good ground?
#194 (permalink) |
Jew Crew
well, the bracket is painted (atleast mine was) and thats what grounds it, the bracket that holds the ballast you can try and grind/scrape off the paint and reattatch it to get a better ground.
but deaodi, its a gas bulb, and when you turn them on, it ignites the gas which gives out a bright flash at first, then goes dimmer and brightens up. thats normal next time you see a bmw or something, ask the guy to turn the headlights on for you theirs do the same thing
#197 (permalink) | |
, ... I going to try that this coming friday (my day off). I'll let you know.
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/58704-post-up-your-hids.html
| Lighting, H.I.D.'s, & Neon - 8th Generation Honda Civic Forum | This thread | Refback | 12-26-2007 09:11 PM | |
| Help with HIDs | decemb3r | Lighting, H.I.D.'s, & Neon | 10 | 03-15-2009 01:46 AM |
| New HIDs | Doug | Lighting, H.I.D.'s, & Neon | 11 | 01-18-2008 03:27 PM |
| HIDs | mmmTIN | Lighting, H.I.D.'s, & Neon | 4 | 12-15-2007 01:53 PM |
| need hids | Statiz | Lighting, H.I.D.'s, & Neon | 3 | 10-28-2006 03:59 PM |
