You would have to retrofit the projector into the headlight housing of your car, using the projectors of the G35 (assuming they fit, I don't know...). You would then have to construct a harness and then buy a D2S ballast to power the projector up.
DIY TSX Retro how to..
CustomLightz
What do you mean by HIDs?
Simply the ballasts and bulbs? If so, you can always get the rebased 9006 D2S bulbs, and cut/splice the power wire to make it work. If you want a retrofit, I am sure you could make the G35 work; and you would once again need to splice/solder to make the bixenons and the ballasts to work. If you are interested, you can PM us, and I can make you a pnp wire harness for either application. However, I don't carry 9006 based d2s bulbs; if that's the route you want to go. Thus, you would need a pair...hit up XenonDepot, the HID kit vendor for this site, and see if they got any for sale. :)
Custom Lightz LLC - HID Retrofit Specialist. www.customlightz.com 804-366-9551 Custom Lightz on 8thcivic.com http://www.8thcivic.com/forums/forumdisplay.php?f=150 Group Buy http://www.8thcivic.com/forums/custo...ml#post2887889 |
#7 (permalink) | |
I'd go for 4,300K or 5,000K. You see people going 5,000-6,000K because they want that hinge of blue that OEM projectors give off when you look at the colour band. All these kits are plug and play. Only downfall is the glare you'll get.
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/50311-need-help-my-hids.html
| Lighting, H.I.D.'s, & Neon [Archive] - Page 3 - 8th Generation Honda Civic Forum | This thread | Refback | 12-20-2007 07:32 PM | |
| Are these HID's ok? | Hondacivicsi23 | Lighting, H.I.D.'s, & Neon | 23 | 05-28-2007 12:57 PM |
| ANYONE have HID's in there FOG's What do you guys think ? ? ? ? | coach2fast | Lighting, H.I.D.'s, & Neon | 27 | 02-18-2007 10:41 PM |
| HID's in my 07' Si... | roadrunner1659 | Lighting, H.I.D.'s, & Neon | 12 | 12-31-2006 01:40 PM |
| Highbeams w/ HID's | brooklynscat69 | Lighting, H.I.D.'s, & Neon | 19 | 10-17-2006 11:40 PM |
| Questions about Lights (HIDS) | Kabs | Lighting, H.I.D.'s, & Neon | 6 | 11-17-2005 08:19 AM |
