Retro help-Wrong Harness?
I ordered the following harness from XenonDepot:
http://www.xenondepot.com/product.php?product_id=50 9006 I'm in the process of a retrofit on my 07 Civic EX, I'm using TSX ballasts/bulbs-- This harness does not plug into the TSX ballasts nor does it look plug into the factory bulb harness on my car, even though it looks like it will it won't lock tite Are there any harnesses out there that will plug into the TSX ballasts? Last edited by geminialg; 07-28-2007 at 06:02 PM. |
I believe all ballasts have different power plugs and these harnesses are universat fit. You have you wire it in yourself or find a TSX ballast plug and wire it into that and plug it in. But the harness should plug right into your factory 9006 harness.
#5 (permalink) | |
![]() Join Date: Sep 2006
I Love Kristina
and because you know which one is positive and negative withthe picture i provided above, then it'll be a breeze to install. |
CustomLightz
Chris is absolutely correct. Those are the correct ground and positive. The TSX ballasts are almost always sold without the ground/positive plugs. What I do for my customers is that I buy the small female plugs, which fit perfectly over each prong, and solder that to the pnp wire harness. To secure it even further, though, not needed, I also add hot glue the plugs in place. I assume clear silicone would be just as efficient; though, it takes longer to cure. The only warning I got to tell you about the TSX ballasts, is the ignition wire, and the cap, which are very fragile and tend to go out before the actual ballast. Also, the TSX ballast are one of the most sensitive to water; thus, place them securly and away from water. Hope this helps
Custom Lightz LLC - HID Retrofit Specialist. www.customlightz.com 516-241-9112 Custom Lightz on 8thcivic.com http://www.8thcivic.com/forums/custom-lightz-hid-retrofit-specialist/ Custom Lightz: Fog-Light Retrofit http://www.8thcivic.com/forums/custo...rofit-ftw.html
| HID Retro wiring harness | SiliconX | Lighting, H.I.D.'s, & Neon | 2 | 06-29-2007 02:58 PM |
| K2 fogs..I think I have the wrong harness? | grcivicsi06 | Lighting, H.I.D.'s, & Neon | 4 | 04-04-2007 04:25 PM |
| No pics, Can you QC my HID harness, text only | phillipguru | Lighting, H.I.D.'s, & Neon | 7 | 01-24-2007 10:59 PM |
| Some help with Metra Wiring Harness | 06Fg2 | I.C.E., Electrical, Security, & Navigation | 2 | 09-26-2006 07:47 AM |
