Old 03-21-2007, 01:46 PM   #61 (permalink)
You're doing it wrong!!
Gonzo's Avatar
I am interested in putting clear/chrome turn signals that illuminate amber in an FG2's front headlights.
Is the current choice only those chrome incandescent style bulbs? I hear they aren't very bright which makes me apprehensive about getting some, but I want cleared headlights. I've seen no example of anyone putting led front signals in their car.
Gonzo is offline   Reply With Quote
Old 03-21-2007, 01:59 PM   #62 (permalink)
reelbigfish241's Avatar
Jason dSLR Squad #27
I have LED turn signals in the rears right now and they are brighter than the incandescents because of the radially mounted LED's on the bulb. I am going to be clearing my headlights over the summer and already have my chrome incandescent bulbs, but may also try LED's.
The biggest issue with LED's in the front is heat, but the touch test after driving for a while the turn signal area wasn't hot at all while the headlight area was.
I'll still give a shot though.
reelbigfish241 is offline   Reply With Quote
Old 04-01-2007, 07:13 PM   #63 (permalink)
bonith's Avatar
What the reverse light for the coupe ?
bonith is offline   Reply With Quote
Old 04-01-2007, 10:50 PM   #64 (permalink)
inyong1988's Avatar
BIPPU
so does the trunk and dome lights have different size of the bulbs?
inyong1988 is offline   Reply With Quote
Old 04-08-2007, 12:01 AM   #65 (permalink)
Bambamsd's Avatar
Yes, the trunk is a 194 and the map, dome lights are 31mm festoon bulbs.
Bambamsd is offline   Reply With Quote
Old 04-08-2007, 07:14 PM   #66 (permalink)
Im Not Going Anywhere!!
CrackThatTec45's Avatar
im trying to convert the bulbs to LED on the site
CrackThatTec45 is offline   Reply With Quote
Old 04-08-2007, 08:42 PM   #67 (permalink)
Gonzo's Avatar
I received and attempted to install some LED's for my front signals on Friday. I'll have more to say in a few days (depending on the response of autolumination concerning their return policy) but to suffice for now, I'd recommend Silverstars.
Originally Posted by OEM_SI View Post
Are you a female?
Originally Posted by MFDOOM44 View Post
no but i have a vagaina
Originally Posted by twix562 View Post
Wow! Sleeper! I like!
Old 04-08-2007, 08:44 PM   #68 (permalink)
i kinda just want the plate light LED, to have the "Lexus plate look"
Old 04-09-2007, 10:06 PM   #69 (permalink)
Gonzo's Avatar
If you are looking for plate LED's, articsilber recommended some to me which I ordered last week. They should be here any day now. Once I get them installed I will post my opinion.
Are you a female?
Old 04-11-2007, 12:50 AM   #70 (permalink)
Bambamsd's Avatar
Well, here are some pictures of my LEDs.
Old 04-16-2007, 09:28 PM   #71 (permalink)
whos_1st's Avatar
Thomas
I'm also replacing the plate lights, but i cant get the bulb out.
Am i supposed to just yank it out? cuz it feels like its gonna break. i tried squeezing the 2 metalic pieces but my fingers arnt small enough, so now wat?
whos_1st is offline   Reply With Quote
Old 04-16-2007, 09:31 PM   #72 (permalink)
should just be able to pull it out with a little pull.....is it really fighting you that much b/c it really shouldnt?
Old 04-16-2007, 09:57 PM   #73 (permalink)
Mad Destroyer
truflip's Avatar
supposed to yank it out. hold it from the base as much as u can.. if u have big fingers.. uhmm.. i guess wear some rubber gloves so that they grip the bulb more? as long as u dont squeeze on it too hard, it shouldnt break on u
Project 8 - October 2008 Photography Challenge "Physical Traces"
truflip is offline   Reply With Quote
Old 04-16-2007, 10:03 PM   #74 (permalink)
Dont Mess With This Zohan
GETxERxDONE's Avatar
Nick
dont forget to wiggle (the bulb not you)
GETxERxDONE is offline   Reply With Quote
Old 04-17-2007, 09:41 AM   #75 (permalink)
Bambamsd's Avatar
I had a little problem with it also, but you just pull it out.
Old 04-26-2007, 12:13 AM   #76 (permalink)
jballer187's Avatar
Jonny
sub'd
jballer187 is offline   Reply With Quote
Old 05-12-2007, 02:53 AM   #77 (permalink)
Originally Posted by Si4Life
dont waste your money on those wack led bulbs......i am on my second set.....pooooooops.
Where did you get your led's?
hondab1015 is offline   Reply With Quote
Old 05-29-2007, 09:18 PM   #78 (permalink)
Coop's Avatar
Coop
worst case scenario if you break the bulb, just use needle nose pliers to pull the metal part out.
Coop is offline   Reply With Quote
Old 05-29-2007, 09:25 PM   #79 (permalink)
Coop's Avatar
Coop
Originally Posted by HkyGrL2
Someone help me here. I've read all the posts, but looks like everyone had a diff. point of opinion as far as the number for the front light.
I want to get bulbs for my front(i'm clearning headlights) and back turn signals that are CLEAR but show AMBER color when turned on.
Front = #3157 ???
Back = #7443
Am I correct in believing those are the numbers? What type of bulb do I get. Also, which site or store(like pep boys or advanced autostore) do you recommend?
Someone told me of this site http://autolumination.com/7443_7440.htm
but there are soo many to choose from. What type of light should I go with, LED? I want one that will DEFINITELY show up during the day and I also DON'T want to have to install anything. I basically need the bulb to just be switched out with the old one....what to do what to do
anyone have any luck to answer her question, i am curious too. also what can i do with the bright headlamp to keep it close to the same color as my HIDs, which are 6000K.
Old 06-11-2007, 04:18 PM   #80 (permalink)
I'd like to see a complete tailight assembly with l.e.d strips and resistors built in that you can just plug and play, made availible. Maybe in a red and clear housing! But not like those cheap looking "euro/altezza" ones that look like they came off of some kind of ufo.
son of man is offline   Reply With Quote
Foglight Instructions Silver8th Inside and Out 17 02-28-2006 04:19 PM
Alarms GhostOp Civic Coupe And Sedan 8 02-05-2006 10:23 PM
Anyone here CCNA certified? Kabs Water Cooler 4 12-23-2005 01:32 PM
10 inch Alpine Type-S Sub Kabs I.C.E., Electrical, Security, & Navigation 3 12-05-2005 09:26 AM
you know it's 2005 when webby Water Cooler 2 10-09-2005 04:34 PM
