Old 06-10-2007, 10:38 PM   #1 (permalink)
FG Squad Member #15
Retrofit Gurus....lights not working....
Well the other night I drove my brothers home after whooping their asses in tennis , and my lights were working fine. I turned off my car, picked up some shit, then went back out and headed to my apartment. Lights worked fine. Then I turn off my car for a little bit, go for a ride on the bike, and then decide to take the car to go show it off at the local hang out. I get in, start it, and turn on the headlights.....no light at all. Everything else works, but headlights are just not powering up. I checked the grounds on my ballasts, nothing got wet, and I also check all the fuses dealing with my headlights (under dash, under hood, and in wiring harness). Am I safe to say that my ballasts died? I got my retro from CustomLightz and I called Bjorn telling him my situation and he said it's probably the ballasts, so I ordered some new ones, but what else could it possibly be?
Spark Notes: HIDs were working, turned car off, then tried to use headlights and nothing. All grounds and fuses good. Suggestions?
06Fg2 is offline   Reply With Quote
Old 06-10-2007, 10:43 PM   #2 (permalink)
striker_1818's Avatar
I HATE Stephanie
do you hear any buzzing sound?
striker_1818 is offline   Reply With Quote
Old 06-10-2007, 10:48 PM   #3 (permalink)
FG Squad Member #15
From the ballast? No. O and the relay is good...I can here that clicking when I turn them on or off.
Old 06-11-2007, 12:30 AM   #4 (permalink)
I HATE Stephanie
then it's the ballast lol
Old 06-13-2007, 09:48 AM   #5 (permalink)
NIGHTHAWKSI's Avatar
Ian
i find it hard to beleive that both ballasts will die at the same time...very unlikely. check your wiring between your relay and the ballasts. you might have a loose wire somewhere.
i assume you are using OEM ballast and not some cheap korean kit...they should last VERY long.
NIGHTHAWKSI is online now   Reply With Quote
Old 06-13-2007, 05:54 PM   #6 (permalink)
caveman74's Avatar
Kevin
If you are using ONE relay then both would go out. I would check that first, much cheaper.
caveman74 is offline   Reply With Quote
Old 06-17-2007, 02:10 AM   #7 (permalink)
FG Squad Member #15
Turned out to be the damn relay. I checked it and heard it clicking, but the ballasts were getting no power. $13 fix FTW....thanks guys.
dash lights arent working. honda06si Mechanical Problems & Technical Chat 18 03-30-2007 10:00 AM
Custom Smoked Head/Tail Lights FG*SQUAD Nick Lighting, H.I.D.'s, & Neon 11 03-13-2007 10:41 AM
HELP!! Trunk lights not working sKiNNyazN5o4 Do It Yourself Articles 6 12-31-2006 11:16 PM
Caution: Ebay Coupe fog lights from Dynasty Auto (Long story) xtv-sidecar Lighting, H.I.D.'s, & Neon 32 08-22-2006 10:33 PM
retrofit projectors slik1017 Lighting, H.I.D.'s, & Neon 18 08-11-2006 10:41 PM
