Old 06-09-2007, 01:52 PM   #1 (permalink)
0oE
0oE's Avatar
highbeam bulb install
Is it easier to go through the inner fender plastic or through under the hood?
0oE is offline   Reply With Quote
Old 06-09-2007, 02:03 PM   #2 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
Ruthless909 is offline   Reply With Quote
Old 06-09-2007, 02:12 PM   #3 (permalink)
reelbigfish241's Avatar
Jason dSLR Squad #27
Follow the manual, it tells you the easiest way. With my EX (not sure if it's same on the Si) you have to pop out the collant resovoir in order to get to the bulb.
The high beams are MUCH easier to change then the low beams, I just did both yesterday.
reelbigfish241 is offline   Reply With Quote
Old 06-09-2007, 02:26 PM   #4 (permalink)
inyong1988's Avatar
BIPPU
why would you go with the fender??? I wouldn't bother my fender for high beams. its not ur front turn signal bulbs. just pop up ur hood and do it.
inyong1988 is offline   Reply With Quote
Old 06-09-2007, 03:17 PM   #5 (permalink)
Special Ringpop's Avatar
On my Si coupe, the passenger side high beam is the easiest of all four bulbs to get at. Nothing to remove, nothing to go through.
The high beam on the driver's side requires you to remove the coolant resevoir (super easy), and then its a cake walk to put the driver's side high beam on. Then you need to put the coolant tank back in its holder, which is ridiculously difficult and will probably elicit many cuss words.
The low beams are super easy if you have small arms and hands, you take a screw out of the inner fender walls (turning your tires right (for driver's side) and left (for pass. side) makes it much easier.
Originally Posted by ImTheVoiceofGod
This was basically the "your mom" of this conversation. A statement meant to mean "I have nothing usefull to contribute as all of my resources have been exhausted. But I am not man enough to admit this so I will now resort to childish bickering."
Special Ringpop is offline   Reply With Quote
Old 06-09-2007, 05:46 PM   #6 (permalink)
if it wasn't so damn necessary I was about to rip that resevoir out and throw it into the street. That was easily the hardest part of installing high beams, haha
Old 06-09-2007, 05:56 PM   #7 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Agreed... that coolant reservoir is the biggest piece of crap ever. I wanted to take out a rifle and shoot that thing when I couldn't get it back in.
Old 06-10-2007, 09:57 PM   #8 (permalink)
0oE
0oE's Avatar
LOL great, i cant wait. I did the lowbeams through the fender as was able to get both arms in there with only taking one plastic screw out.
Old 06-10-2007, 10:14 PM   #9 (permalink)
SIchodelic's Avatar
Nam
I know what you mean, I had to try a lot of times to get it back on correctly
SIchodelic is offline   Reply With Quote
XenonDepot HID Install Guide unplugged Lighting, H.I.D.'s, & Neon 64 08-05-2008 09:34 PM
Install Har Kar Drive & Play on 2006 Civic Nickelbed_Home I.C.E., Electrical, Security, & Navigation 8 02-02-2008 12:12 AM
Ordering hids but dont know the bulb size 2007 civic skippy911 Lighting, H.I.D.'s, & Neon 5 03-23-2007 04:10 PM
How do I install the HPF front lip for the 06 Si CIVI7 Civic SI 2 09-18-2006 02:32 PM
IMG install?!? SonicK20Z Bolt-Ons And All-Motor 1 06-21-2006 05:45 PM
