Old 06-08-2007, 06:33 PM   #1 (permalink)
b0yd07's Avatar
Michael
06 K2 fogs: switch
I think I'm going to buy these off of ebay soon but I don't understand how the switch will fit into that area.
Look at the picture
My car has the mirror adjuster there and there is not a chance in the world the little adapter they include will fit in there. Maybe that's the switch for the sedan? I know the sedans have the mirror thing on the door.
Also, how difficult is it to install these things ourselves?
Any help would be appreciated. Thanks.
b0yd07 is offline   Reply With Quote
Old 06-08-2007, 06:48 PM   #2 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
If I'm not mistaken, that's just a generic picture of a harness. The K2 Motor Fogs for the 2006+ Civic will wire directly into the car and operate with the DRLs or headlights, so there's no switch needed.
This is my guess since my friend has this kit.
Old 06-15-2007, 11:36 AM   #3 (permalink)
07blackonblack's Avatar
Edis
its hard to install and the swich with 3 spots you see isnt needed just the one switch itself. It fits right next to the Power window adjuster. Just pop it out and put the swich in.. the wiring trough the engine was a pain..
07blackonblack is offline   Reply With Quote
Old 06-15-2007, 11:39 AM   #4 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
they should work.
is Missy a squirter?
http://killyourself1.myminicity.com/tra build my city.
Old 06-15-2007, 12:31 PM   #5 (permalink)
steve davidson
I just installed these this weekend on my 07' fg2. What i did was put the new fog light switch in the spot where the VSA switch was and i routed the VSA switch into the little tray just below the panel were the mirror switch's and VSA switche is. The tray,when you pull the dash apart is a perfect place to install the vsa switch. I put it there because i never use the VSA i just needed to be able to get to it so i could turn it off. I'm going to do a DIY for people who need to install these ebay fogs on their 07's and dont want to buy the light stalk from honda and spend a ton of money. I'll keep u guys updated.
swarm is offline   Reply With Quote
Old 06-15-2007, 12:35 PM   #6 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
theres no need to wire anything thrue the engine.
Old 06-15-2007, 02:40 PM   #7 (permalink)
jric1308's Avatar
I think he means attaching the harness in the engine bay( like under the window fluid container). I did an install with my friend and that was a PITA
jric1308 is offline   Reply With Quote
Old 06-15-2007, 02:52 PM   #8 (permalink)
b0yd07's Avatar
Michael
I have an '06. I think they're different.
Old 06-15-2007, 02:54 PM   #9 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
there should be a slot there for it. it has a plasctic cover that you need to remove to add the button.
Old 06-15-2007, 03:31 PM   #10 (permalink)
aznives3's Avatar
if you look at the switch on K2's auction, it shows the switch, and then 2 empty panel things that make up what looks to be 3 switch slots.
This is because the DX models do not have power windows, so for DX owners, they would need to replace the whole thing in their dash, and this would cover up the holes left behind if they install fogs.
For all the other owners, the switch in their auction link, as other have said already, just pops out of the DX "triple slot piece" and slides right into the empty peice on your existing dash. You can see the slot for it right beside the power window button, all you have to do is pop it out once you have the dash off.
Gluck!
aznives3 is offline   Reply With Quote
Old 06-15-2007, 06:05 PM   #11 (permalink)
b0yd07's Avatar
Michael
Thanks aznives3
So do the fogs not come on automatically when the lights are turned on? You have to turn both on?
Old 06-15-2007, 07:19 PM   #12 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
yes you have to push the button.
Old 06-21-2007, 07:13 AM   #13 (permalink)
mrk
mrk's Avatar
how would the 07 civics with VSA install the K2 fogs and keep the VSA switch?
mrk is offline   Reply With Quote
Old 06-21-2007, 01:48 PM   #14 (permalink)
steve davidson
ok here is how you do it. You follow the install as normal. when you get to the point when you have a choice to either put the new switch in the VSA spot what you do is take out the VSA switch and put the included k2 switch in the VSA spot. There is a little tray below the VSA switch and mirror adjustment panel. This tray (when you take the panels apart to install the harness) is where I retroed the VSA switch. I ran the VSA through from behind the dash and into that little tray. I did this because all I use the VSA for is the rain. So when I turn my headlights on my fogs come on and all I have to do is reach down and tap the VSA off every time I start the car. I will be doing a diy soon on how to do this.
Old 06-21-2007, 02:03 PM   #15 (permalink)
qwerty :)'s Avatar
kyle
i have an 07 with the k2.. and i just kept the VSA switch where it was.. and turned the foglights on by pressing the switch, then left the switch in the dash.
so when i lock/unlock the car the foglights blink with everything else, and when i turn my lights on the fogs automatically come on.
i wouldnt have it anyother way!
qwerty :) is offline   Reply With Quote
Old 06-21-2007, 08:40 PM   #16 (permalink)
mrk
mrk's Avatar
So if you leave the fog light switch on inside the dash, it'll stay off unless you have your headlights on, right? If that's the case, I'm going to order a pair right now. I usually drive without VSA during the summer and I click the VSA switch before every drive.
Old 06-21-2007, 09:40 PM   #17 (permalink)
qwerty :)'s Avatar
kyle
correct, my switch is always on, but lights only come on with the reagular lights, or just the turn signals too..
and i like how they flash when i lock/unlock :)
Old 06-22-2007, 02:54 AM   #18 (permalink)
Firestrife's Avatar
Keenan
*sorry for a hijack but*
So i was thinking of getting a pair of these they good?
Firestrife is offline   Reply With Quote
Old 07-24-2007, 09:47 PM   #19 (permalink)
hiphopaddict's Avatar
Kevin Williams
So if you leave the switch in the on position and leave it in the dash, do the fog's only come on with the headlights? What about if you turn on the parking lights, do they light up then as well? I have an '07 as well, and I don't want to move my VSA switch.
On another note, how mutch does the stalk for the '07 cost, and how hard would it be to install?
Why do you all not use VSA all the time. I turn it off if I'm drag racing, but that's about it. It helps in other situations besides rain, and snow. It also helps if you lose control in a curve. I've felt it before, saved my ass!
hiphopaddict is offline   Reply With Quote
Old 07-28-2007, 03:52 PM   #20 (permalink)
Can someone take a picture of what it looks like with the switch in? Does K2 fogs have the Blue connector to make the dash light up when the fogs are on? if not is there a mod yet?
Sznaps is offline   Reply With Quote
07 K2 Fogs. Different Question. Promise. TheJamster Lighting, H.I.D.'s, & Neon 15 07-31-2007 02:42 PM
On/Off switch for Cheapo fogs in an 07 Si? MetalTark Lighting, H.I.D.'s, & Neon 2 05-20-2007 06:20 PM
Question about K2 fogs mhuynh Lighting, H.I.D.'s, & Neon 11 03-04-2007 11:47 AM
07 Si coupe:OEM fogs or K2 xmx250 Lighting, H.I.D.'s, & Neon 3 02-02-2007 08:57 PM
Re: Auto unlock on all doors koreth Civic Coupe And Sedan 44 10-16-2006 12:27 AM
