night shift whore
you have to buy the ones that are specific for the 07.. they are on the lever where your head light switch is at it comes with one to replace that whole part so when you order it make sure it's for an 07 or it will have the switch to be in place of the vsa
#3 (permalink) | |
#4 (permalink) | |
Im Not Going Anywhere!!
you cant just cut into the plastic dash. it wont work. the required plastic that the switch needs to "bite" into is much thicker than what the stock dash is made to. thats why they have the little black shroud for the vsa button and the power window switch. the switch will move around. either; A. buy the real switch for our 07 OR B. mount the switch to the roof portion of the coin tray.
#10 (permalink) | |
didnt think of that my man!! damnit!
#14 (permalink) | |
#15 (permalink) |
night shift whore
good question i havn't seen the harness of the aftermarket ones, but if you would like if someone takes pictures of all the plugs that are on the aftermarket ones, i would be more than willing to take picture of the OEM harness that i got when i bought my OEM fog lights from honda.
#16 (permalink) |
i bought the same kit from ebay and have the same issue. I use to have an 03 accord sedan LX and recall that it had a OEM dash pate (where the sunroof buttons were located but the LX didnt have the sunroof.) I went to the dealer and purchased the same part, sure enough, perfect fit, i mounted the switch directly under the coin holder
| can i get the dyi to installing fog lights on sedan | 1sole | Lighting, H.I.D.'s, & Neon | 0 | 05-24-2007 10:46 PM |
| I want to put driving lights in the fog light location | jreesnc | Lighting, H.I.D.'s, & Neon | 15 | 04-01-2007 09:56 PM |
| Honda factory installed fog lights.. | 06bklcivicsi | Lighting, H.I.D.'s, & Neon | 0 | 01-25-2007 11:15 PM |
| FOG LIGHTS + Veichle Warranty | VeGeTa-X | Lighting, H.I.D.'s, & Neon | 3 | 10-02-2006 02:52 PM |
| Caution: Ebay Coupe fog lights from Dynasty Auto (Long story) | xtv-sidecar | Lighting, H.I.D.'s, & Neon | 32 | 08-22-2006 10:33 PM |
