Old 04-21-2007, 03:04 PM   #1 (permalink)
** Help me find foglight switch/cover **
where can i find this only? what is the part # for oem? what is it called?
will rep useful info!!
irichard is offline
Old 04-21-2007, 06:56 PM   #2 (permalink)
no one wants to help?^
irichard is offline
Old 04-21-2007, 07:04 PM   #3 (permalink)
Black_civic_Si's Avatar
Item no#77225-SVA-A00ZA
here the link https://www.hondapartsdeals.com/hond...ponent=B++3710
Black_civic_Si is offline
Old 04-21-2007, 07:33 PM   #4 (permalink)
^ 2dr & 4dr are the same? cause that 2dr parts...
irichard is offline
Old 04-21-2007, 07:38 PM   #5 (permalink)
honda06si's Avatar
justin
i think the 2 & 4 should be the same....but then again the 07's have the vsa switch so its probably diffrent.......
honda06si is offline
Old 04-21-2007, 07:41 PM   #6 (permalink)
they are the same thing/same size, should be no fitting issue. What are you trying do if you don't mind me asking you.
Here the fdr version https://www.hondapartsdeals.com/hond...ponent=B++3710
Old 04-21-2007, 07:44 PM   #7 (permalink)
i am planning on putting switches on that thing for stuff like LEDs.. i was thinking of buying the foglight kit since it come with, but i am not to fond of the 4dr foglights, and buying single part from honda is so expensive..
irichard is offline
where to find... bzukeran Inside and Out 6 04-12-2007 03:21 AM
foglight plastic removal? JOKINGFG2 Mechanical Problems & Technical Chat 8 04-11-2007 08:14 PM
Repair damage Foglight & Install. on Sedan Civic4u Lighting, H.I.D.'s, & Neon 0 09-25-2006 11:17 PM
