Old 04-18-2007, 11:03 AM   #1 (permalink)
CrackThatTec45's Avatar
Xenon Depot Install Help!!
I just recieved my Xenon Depot HID kit off another member. Now my question is everything plugs into one another fine, but where it is suppose to connect to the stock headlight harness i only have ONE plug on the kit to be able to plug in to the stock harness. Now with the Xenon Depot kit does it plug into the stock headlight harness in only one spot or does it indeed need to be plugged into both/two of the headlight harness as well? Im a bit lost with this lonely plug, does it plug in only once and work that way then?
CrackThatTec45 is offline   Reply With Quote
Old 04-18-2007, 11:08 AM   #2 (permalink)
:beer:
Mikey6p's Avatar
Mukey
It only needs to be plugged into one of the stock headlight harnesses.
Originally Posted by Celcius View Post
Sorry for being off-topic but is that a picture of a **** stained urinal divider as your avatar?
Mikey6p is offline   Reply With Quote
Old 04-18-2007, 11:37 AM   #3 (permalink)
does it make a difference what harness?
Old 04-18-2007, 12:34 PM   #4 (permalink)
jay3151's Avatar
Juan Carlos
if its the xenondepot 9006 kit,it should connect harness to relay to ballast to bulb. on each side. thats how it is on their extreme kit.
the wire harness for custom lightz retros use one plug and the other is taped up.
jay3151 is offline   Reply With Quote
Old 04-18-2007, 12:55 PM   #5 (permalink)
so it needs to be plugged into both sockets then? b/c i only have one connector
Old 04-18-2007, 12:56 PM   #6 (permalink)
Mabuz's Avatar
Each headlight plugs into the relay (like you already stated), then the relay plugs into one of the factory headlight harnesses...you choose, either one should work. I used the driver's side because it was easier to get to.
Mabuz is offline   Reply With Quote
Old 04-18-2007, 01:32 PM   #7 (permalink)
thanks man....I just got off the phone with Xenondepot directly....very very informative i tell ya....It looks like i got my hands on an older generation of HID kit where it relies only on one harness instead of two seperate harness for each light (like the newer ones) the reason they charged to two seperate relays is because if i blow a fuse with my current kit i have ZERO lights. Where as if there were two seperate relays for each different light if i blew a fuse i still would have one light operatable. So tonight while @ work im gonna test these out before i start ripping stuff apart to see if i can get these to work.
Old 04-18-2007, 09:36 PM   #8 (permalink)
well i did the install tonight. All went well & it looks quite fresh i must say. What happend was i just by passed one of the stock headlight harness and just plugged into one and worked like a charm. Thanks fella's for all your help!!
Old 05-03-2007, 12:21 PM   #9 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
Enjoy
XenonDepot is offline   Reply With Quote
Xenon Depot - Great service/sponsor Iceman Lighting, H.I.D.'s, & Neon 10 02-26-2007 03:44 PM
xenon depot 6500k installed jay3151 Lighting, H.I.D.'s, & Neon 18 12-14-2006 05:59 PM
Selling my Xenon Depot kit...... RITDR Lighting, H.I.D.'s, & Neon 1 11-02-2006 09:20 PM
Cheapest price for Xenon Depot 6K HID kit? duy2006si Lighting, H.I.D.'s, & Neon 0 10-10-2006 09:28 PM
xenon depot 9004 harness sickyute Lighting, H.I.D.'s, & Neon 4 08-29-2006 01:54 AM
