Old 04-07-2007, 07:38 PM   #1 (permalink)
REv2Red's Avatar
Matt
LED's...White or Red??
I'm about to order some LED Tail Lights and I am curious whether people here have purchased white or red LED's for their tail lights. Are the whites too bright?? Are the red's too dim in the daylight??
REv2Red is offline   Reply With Quote
Old 04-07-2007, 10:23 PM   #2 (permalink)
Bambamsd's Avatar
I changed my taillights and I used red. If you use white, it makes the red look pink. One way to remember, is whatever color the reflector is, use that color LED.
Bambamsd is offline   Reply With Quote
Old 04-07-2007, 10:27 PM   #3 (permalink)
Tom1222's Avatar
Tom Smith
Where can you get LED Tailights? I am looking for a set and would be grateful for any information.
Tom1222 is offline   Reply With Quote
Old 04-07-2007, 10:27 PM   #4 (permalink)
TJ213's Avatar
+1, the reflectors / coatings are usually designed to block all the light except the color of the reflector / coatings.
Old 04-07-2007, 10:48 PM   #5 (permalink)
Bambamsd's Avatar
For the time being until the aftermarket catches up, we are talking taillight bulbs. There is only one taillight set that I've seen. I believe it was on ebay. Haven't seen them lit up or on a Civic. If you want to buy the LED bulbs, then you can go to www.autolumination.com or www.superbrightleds.com. You can get the numbers of the replacement bulbs if you go to the civic style section of the forums and get on the lighting thread.
Dash and switch lighting HabaneroGuy Lighting, H.I.D.'s, & Neon 294 07-23-2008 12:23 AM
just in case you need every cereal type from the 80's webby Water Cooler 16 12-09-2007 03:28 PM
Black or White? kez07 Introduction & Pictures 46 08-16-2007 05:30 PM
What color should I get? Taffeta White vs. Rallye Red racersky Civic SI 20 03-27-2006 01:03 PM
