Old 01-29-2007, 05:39 PM   #21 (permalink)
Hail corporate masters.
J-Ro's Avatar
Jason
Originally Posted by brdhouse
you might find some useful info in this thread:
http://forums.clubrsx.com/showthread.php?t=348644
Well, I never even bothered to read that until now... isn't my face red?
That's exactly what I'm going to do when the weather decides to warm up, which won't be for a while
J-Ro is offline
Old 01-31-2007, 04:32 PM   #22 (permalink)
hotrod's Avatar
Michael
When I do this I'll try and take some pictures for a DIY. I got the lexan just need the time to do it.
hotrod is offline
Old 02-01-2007, 07:46 PM   #23 (permalink)
hotrod's Avatar
Michael
So here is what I did.
Bought a small piece of Lexan .093 or 1/16''
First remove your front bumper. You can try to remove your fog lights without doing this but is so much easier just removing the bumper.
Then take out the light. Remove the 3 screws holding it on the bumper, then the 2 screws that are attaching it to the bracket.
Take off the from black plastic piece that holds the lens in place. It has 4 clips that you just have to lift up. Try not to break them off.
Remove the glass that is left in place and also the glue that was holding it in place.
Now the fun part.
Trace the outside of the fog light on the Lexan.
Then cut it out. You can use any method that you would like. I used a Dremel and a file that I had laying around.
Keep filing or sanding until the Lexan fits in place.
I then ran a small bead of silicon around the outside of the fog light to hold the lens in place and to keep water out.
Put the black plastic piece on the front and let dry for a while. Actually thats what mine is doing now. I'm going to let it sit for a few days, then reinstall it.
If you read the posts on the rsx website they are taking out the black metal piece in that surrounds the bulb. I left mine in because my fog light has a small hole in the reflector that allows air ie heat escape. I didn't see that on the RSX fog light. Here are some pics of what I did.
I will post pics of it installed once installed.
hotrod is offline
Old 02-01-2007, 09:28 PM   #24 (permalink)
caveman74's Avatar
Kevin
Nice, Thats the way to do it.
caveman74 is offline
Old 02-01-2007, 09:41 PM   #25 (permalink)
civic4ever28's Avatar
Rob
i just ordered foglights and i was wondering if i should also order the Lamin-x protective film for them is it worth the extra $15
civic4ever28 is offline
Old 02-02-2007, 05:17 AM   #26 (permalink)
Photobucket
Silver8th's Avatar
Nice job, Hotrod.
Where do you get lexan?
Silver8th is offline
Old 02-02-2007, 05:43 AM   #27 (permalink)
caveman74's Avatar
Kevin
go to Home Depot, Its 3.00 for a little sheet
Old 02-02-2007, 07:25 AM   #28 (permalink)
J-Ro's Avatar
Jason
Sweet... nice job hotrod. I reeeeeeally want to do that now! :)
+1
J-Ro is offline
Old 02-02-2007, 08:12 AM   #29 (permalink)
Retread's Avatar
Laminix will help, but it won't save them completely. Plus, it WILL melt to the lens if you have your fog's on for extended periods and the car is not moving.
More so in warmer climates than colder ones. Face it, they are in a vulnerable position that low to the road, so plan on replacing them several times during your ownership of the car. Looking cool, and adding so little illumination to the road is not worth it for me. I won't put any on my car.
The Lexan is a much better idea, but you will get deflection of the light beam, and they won't be as effective as stock. But it WILL protect the lens.
Retread is offline
Old 03-06-2007, 06:20 PM   #30 (permalink)
BubzSI's Avatar
Travis
I did that too w/ my RSX.. Easy as hell.
BubzSI is offline
Old 03-06-2007, 08:49 PM   #31 (permalink)
Civic4u's Avatar
What the temperature range of the Lexan? Good ideas! But I'm afraid it might melt....etc.
Civic4u is offline
Old 03-07-2007, 09:39 AM   #32 (permalink)
J-Ro's Avatar
Jason
-40°F to 280°F, courtesy of http://www.sdplastics.com/polycarb.html
J-Ro is offline
Old 04-22-2007, 07:16 PM   #33 (permalink)
how did u bend it to the desired shape?
lancerx is offline
Old 04-22-2007, 07:41 PM   #34 (permalink)
J-Ro's Avatar
Jason
It doesn't really have to bend that far. Just take out all the glass and all the old sealant, apply new sealant, put the new lexan lens over top and fit the black plastic frame over top. The frame will hold the lexan down and bend it into a slight curve to match the curve in the foglight housing.
J-Ro is offline
Old 04-24-2007, 05:02 PM   #35 (permalink)
I've install this laminx on mine, and I'm not satisfied at all.....the plastic has melted slightly. Strange since it's still cold weather here.......I really regret this stuff, I should have put lexan right away !
seaman is offline
Old 04-24-2007, 05:20 PM   #36 (permalink)
caveman74's Avatar
Kevin
Thats what I have been preaching. Lamin-X DOES NOT WORK. Fogs get too hot for the film. Lexan the fogs and call it a day.
Old 04-24-2007, 05:25 PM   #37 (permalink)
J-Ro's Avatar
Jason
Haha, that's it in a nutshell. The lamin-x wasn't really that expensive, but it sucks to pay the money when they don't do squat.
Epic Northeast Meet quotes:
Originally Posted by portabuddy
People sometimes think I'm pregnant, but I'm actually not.
Originally Posted by jrMartinez24
You don't look Canadian. You look like you're from Boston.
J-Ro is offline
Old 04-24-2007, 05:33 PM   #38 (permalink)
caveman74's Avatar
Kevin
Cost me $4.00 at Home Depot and took 10-15 min to install.
Old 04-24-2007, 05:39 PM   #39 (permalink)
hotrod's Avatar
Michael
This 100% true. Replace the glass with Lexan.
hotrod is offline
Old 04-24-2007, 08:08 PM   #40 (permalink)
I've paid much more than only the ******* laminx....I had to pay also for a replacement lamp.....it was a real bad move !
seaman is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/27206-broken-foglight.html
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 10:14 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 08:22 AM
Dad's vehicle got broken into :-( MordeKyle Water Cooler 16 01-23-2007 12:07 AM
OEM Foglight Kit is excellent Monty Civic Coupe And Sedan 11 10-10-2006 03:53 PM
Repair damage Foglight & Install. on Sedan Civic4u Lighting, H.I.D.'s, & Neon 0 09-25-2006 11:17 PM
