help with fog light install - 8th Generation Honda Civic Forum
Old 08-01-2011, 11:03 PM   #1 (permalink)
i read the other treads and i have a different wiring harness. i have i yellow wire and a red circle connecter from the fog light harness. then on the inside of the car i have a brown connector that i connect to the other brown pin under the pedal a black ground and a yellow wire. then i have this long red wire that i believe connects the 2 yellow ones together. my question is do i even use the brown connector from the harness inside the car since i have no brown connector for the harness outside the car and just connect the yellow wires together with the long red wire from outside the car in through the fire wall and run the red circle connector from the foglight harness to the battery. if so what do i do with the brown connector inside the car and how do i run wires through the firewall. if anyone has an easier way please let me know and i hope i uploaded the pictures right so u can see what i got.
the newguy is offline
Old 08-01-2011, 11:13 PM   #2 (permalink)
Erichelms31's Avatar
Eric
No pics
Erichelms31 is offline   Reply With Quote
Old 08-02-2011, 10:56 PM   #3 (permalink)
this is the connectors that come out from the foglight harness
this is the end piece of the harness inside the car
random red cord that i believe i need to connect the two yellows together
the newguy is offline   Reply With Quote
Old 08-02-2011, 10:59 PM   #4 (permalink)
random red cord that i believe i need to connect the two yellows together and the circle connector goes to the battery. what do i do with the brown or am i wrong.
fog light install mashbash51 California South 4 04-24-2010 09:13 PM
Fog Light Install (Aftermarket) Parking light & Fogs Dark_KnightSi Lighting, H.I.D.'s, & Neon 2 12-29-2009 03:37 PM
Fog Light Install Help! BlackCivic California North 1 03-17-2007 04:56 PM
$350 for fog light install on a Si.... That_Si_Guy Garage 8 06-09-2006 08:00 PM
