#21 (permalink)
Christian
HID bulb shifts light everwhere as in its beam is uncontrolled thus a shield will control it and make the beam sharp. Example: Projectors. The differece with Halogen bulbs is that the HID bulbs produce more than twice the lumens a halogen produces...these high intensity discharged light output is controlled by the ballast. That's why you don't find ballasts with our halogen bulbs in our cars. |
#22 (permalink) |
![]() Join Date: Mar 2006
You don't understand, my friend. I have a projector retrofit in my headlights and I still think you're going about this the wrong way.
And I think the term that you're looking for is REFLECTOR. You are describing the classic reflector headlight- all of them. And contrary to what you may think, even modern reflectors are designed to minimize light above the cutoff. Unless they come that way from the factory (and surprise! there are factory-equipped cars with HID that have reflector technology) many reflector headlights just aren't designed to handle the intensity (high INTENSITY discharge) of D2S or D2R bulbs. So whether your general argument is with reflector technology, HID technology, or with plug-and-play ebay kits remains unclear. You come off as belligerent and condescendingly didactic, and when you combine that with opinions rather than facts (citations, pictures, examples, figures, testimonial, etc), you aren't helping your argument. |
#23 (permalink) |
![]() Join Date: Feb 2006
ok guys seriously we are beating a dead horse here
striker, you do have some points but they could be better expressed to those posting negative rep, why, this is an argument that we are going to be having for the next 5-20 years untill something better comes along. But is the negative rep really necessary seriously if you want to continue this argument go join hidplanet.com and they will be happy to have you join in their discussion, but this is starting to get out of hand here we are always going to have people installing pnp kits in their cars (im one of them), and we are always going to have people stating over and over that the projector retrofit or oem reflector setup is better... WE ALL ALREADY KNOW THIS!! im just asking you guy to give it a rest already Last edited by ethlar; 12-24-2006 at 03:36 AM. |
#24 (permalink) |
Christian
you see...
Halogen reflectors are made for what? Halogen. Why? Because the lumen that halogen bulbs produce are at a mere 700. HID reflectors are made for what? HID. Why? because the lumens that D2R HID bulbs produce can be handled by such reflectors. I even gave you an example. The G35. For instance, take a look at a halogen projector vs an HID projector. After that, gather your own conclusions. BTW loving the TW si |
#25 (permalink) |
![]() Join Date: May 2006
Phil
Is there such a thing as a complete HID kit that includes the projector? Like an all-in-one solution? Or is the only way to get that nice sharp cutoff on an FG2 the TSX retrofit (or any other lens retrofit). I guess what I'm saying is, is the only way to get a sharp cutoff to take apart my stock lens? Or can I buy a HID headlight setup with the lenses already in it? I have seen the PNP kits in person, and, they are OK, but one of my friends has an RSX with a retrofit, and WOW. The cutoff is beautiful, and even more amazing when you are in the car. I want it.
#26 (permalink) |
Kevin
There are 4 different setups for lighting
Reflective HID- Which is made for D2R bulb and reflects the light up. even the reflector is different than a stock halogen setup ( Toyota Sienna ) NOTICE the bulb reflector, It is putting everything up! ![]() Reflective Halogen-- This is your standard lighting. This puts light everywhere in the housing and is made for halogen bulbs. NOTICE the bulb reflector, It is allowing light on the sides... ![]() HID projector-- Made for a D2S bulb, any other bulb will not fit unless it is modified. Halogen projector-- This is made for Halogen only, If you install HID, the focal point will not be the same and you pattern will be very weak. Tried it with TYC projectors already Its anyone's judgement on what they want to use. I wanted HID 4 years ago in my 02' Accord. I planned to go the cheap way and it failed. So I went the projector way. I got all OEM stuff and had no problems. That is the price you pay for going PnP, is the ballast and bulbs If you buy a kit for $200.00, I can guarantee you it will not last that long. Something will fail within 2 yrs or sooner Read up on this link. It is very informative and better than going to Hidplanet http://faqlight.carpassion.info/ It has everything you need to know about lighting |
#27 (permalink) | |
#28 (permalink) | |
#30 (permalink) | |
Christian
Anyways, the casper shield makes you get less glare from your stock housing but those kits cost more. Hence the phrase "you get what you pay for". Merry Christmas everyone! and bump for my tsx projectors sale...150 bucks only :-p no1 on hidplanet seem to want them let me post them here. |
#32 (permalink) | |
casper shields are only available for 9007 and other dual filament type applications, to prevent light from hitting the high beam parts of the reflectors |
#33 (permalink) | |
Christian
#34 (permalink) |
Who can tell me why the HID reflector on a Lexus IS300 is optimized for a HID setup whereas my OEM halogen reflector is not?
To clarify: What makes a HID reflector fundamentally different from a halogen reflector? Isn't the only difference the type of bulb? (D2S versus the D2R.) |
#35 (permalink) | |
Christian
D2S = Projector HID D2R = Reflector/Reflective HID The design is different, size, positioning etc all tested from the manufacturer. Even if it may look the same at first glance, it is different. Every reflector is made to handle its respective lumens coming from its corresponding bulbs for which they're designed for. Last edited by striker_1818; 12-26-2006 at 07:04 PM. |
#36 (permalink) | |
the light emitted from the HID bulb is in a different location from the light emitting filament on the halogen. Notice on the H4 bulbs that the low beam is in a different location from the High beam filament. You can switch the beam pattern by simply relocating the light source. Its pure geometry. |
#37 (permalink) | |||
#38 (permalink) | |
Christian
with leds I still don't understand why a multiple-led based headlight would produce more light than an HID projector based headlight? |
#39 (permalink) | |
Kirk
Amen. |
#40 (permalink) | |
Light is not controlled or limited by the HID ballast. The ballast is simply a transformer, converting 12 volts to some 20 kajillion volts or whatever it is required to produce an arc in the HID bulb. It IS limiting voltage, but not trying to limit light intensity as you state. Halogen bulbs do NOT have ballasts......correct.......but its not because halogen lights need to control the output, its because the halogen bulb is designed for 12 volts. And to further analyze, you could use these PNP HID kits. You would either have to engineer and design a shield to limit the light output to mimic the same light emission of the halogen bulb or you would have to stick the PNP bulbs in a projector, which is NOT sensitive to filament location. |
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/24190-what-you-need-know-about-hid-vs-hid-kit.html
| What you need to know about HID vs HID kit - 8th Generation Honda Civic Forum | This thread | Refback | 01-03-2008 12:36 PM | |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| PureVision HID Kit? | chriskurn | Lighting, H.I.D.'s, & Neon | 2 | 10-13-2006 04:32 PM |
| Need help on installing HID kit. | JDM_civic | Lighting, H.I.D.'s, & Neon | 5 | 09-12-2006 07:01 PM |
