Old 12-22-2006, 07:33 AM   #1 (permalink)
AznSupastar's Avatar
2007 Taffeta White Si Coupe
Where did u place ur ballast (plug & play HID)?
i'm just curious where ppl mount their ballast from their HID kits...low beam or fog HIDs, i need some idea where to place them so that they are somewhat easy to access in case of anything. i noticed some people tuck them inside the bumper, but isn't it a hassel if u need to plug/unplug something and u need to remove ur whole bumper just to do that?
thanks guys, some pix of where u place ur ballast would be appreciated!
AznSupastar is offline   Reply With Quote
Old 12-22-2006, 08:02 AM   #2 (permalink)
placement
I placed the driver's side one in front of the battery right next to the coolant overflow tank. Removed the tank. Took out the little plastic clip for the hose from the tank to the radiator. There is a 10mm bolt already there. I got the idea from many of the pictures already posted. For the other side, I drilled a hole in a similar spot and mounted. Pretty easy. Much easier than actually getting to the bulbs.
consumer22 is offline   Reply With Quote
Old 12-22-2006, 09:41 AM   #3 (permalink)
xmx250's Avatar
I also need to find out where to mount my ballast.
Also where did you guys ground and how did you connect to the battery.
xmx250 is offline   Reply With Quote
Old 12-22-2006, 10:43 AM   #4 (permalink)
n00b retro whore
ethlar's Avatar
my ballasts are mounted under the headlights, i dont have any pictures of it but if you take off the bumper it will make sense. And im using the relay kit from the auction to connect my kit to the battery, red to positive and black to negative
Old 12-22-2006, 01:16 PM   #5 (permalink)
Avenger's Avatar
Rob
I just kinda stuffed mine in - driver's side beside the coolant tank, passenger side behind the brake lines there. They're not going anywhere........just kinda sit in there.
Avenger is offline   Reply With Quote
Old 12-22-2006, 01:37 PM   #6 (permalink)
PoLiShPrInCe's Avatar
mine are on the frame just behind the fender... there is a spot up there that is a perfect fit for the ballast... i would take pics but i dont want to go under there again
PoLiShPrInCe is offline   Reply With Quote
Old 12-22-2006, 02:10 PM   #7 (permalink)
tomasro's Avatar
Turner
HID Fog Lights: I mounted my ballasts actually ON the support brackets for the lights themselves.
Low Beam HIDs: Mounted the ballasts using the metal holders to the frame itself. I drilled a pilot hole, and them used self tapping Hex metal screws to finish off the procedure. The passenger side ballast is mounted just next to the brake controller, and right above the high beam (kinda next to the hinge for the hood proper-upper). And the Driver's side ballast to the right of the battery, just next to the coolant reservior...again tapped and drilled into the frame.
Hope this helps!
tomasro is offline   Reply With Quote
Old 12-22-2006, 02:18 PM   #8 (permalink)
a birdie w/o a Katana....
Nomar06's Avatar
I placed mine on top of the mount that hold the airbag sensors. Basically its between the wheel well and the headlight housing. It already had a whole on the metal so I got a screw that sat flush. If you look in the engine bay it looks like I didnt do anything.
Nomar06 is offline   Reply With Quote
Old 12-22-2006, 02:57 PM   #9 (permalink)
dentrecords's Avatar
Rep for anyone that posts pics :)
Originally Posted by 2fast4u2
yee haaawwww
Old 12-22-2006, 03:16 PM   #10 (permalink)
JeShUa's Avatar
add camber and stir
rep please
Old 12-22-2006, 03:24 PM   #11 (permalink)
Exeon's Avatar
lost the mod bug
passengers
drivers
on drivers side i hooked the tie wrap around one pin clips of the air box
kinda ghetto, but no vibration/noises when driving :) just gotta clean up the drivers side wires
Exeon is offline   Reply With Quote
Old 12-22-2006, 03:41 PM   #12 (permalink)
Moderator
sickyute's Avatar
Marvie
need to find my post with pic.... BRB...
Shift when it blinks!
Old 12-22-2006, 03:47 PM   #13 (permalink)
Moderator
sickyute's Avatar
Marvie
now for the pics of where i have my old school ballasts installed...
passenger side
driver's side
grounded at the black screw (fender screw) on both driver and passenger side.
the power wire from the passenger side was ran under the front cowl to the battery...the one on the driver's side u can run anywhere u feel like to the batter cuz it's right there. Just make sure to secure the rest of the wire.
both the ballasts and the relays on the wire harness came with mounting brackets which made for a pretty easy install using the pre-existing screws on the car as shown...they are torx/star screw...
Old 12-22-2006, 03:49 PM   #14 (permalink)
Moderator
sickyute's Avatar
Marvie
search next time please
Old 12-22-2006, 03:59 PM   #15 (permalink)
^^ now that is a clean install location to you
Old 12-22-2006, 07:14 PM   #16 (permalink)
Tim
Super Moderator
Tim's Avatar
Denso ballast for low-beams fit under the headlights:
Kit ballasts for fogs attached to the frame:
Tim is online now   Reply With Quote
Old 12-22-2006, 08:28 PM   #17 (permalink)
Nomar06's Avatar
Look at the arrow, thast where I placed mine. No water at all!!!!! Sorry i stole the pic Tim
Old 12-22-2006, 08:31 PM   #18 (permalink)
Nomar06's Avatar
Wait a minute! Should I put the ground wire to the relay to the frame???? My instructions said to hook it to the - terminal on the battery.
Old 12-22-2006, 09:17 PM   #19 (permalink)
tennisfan16's Avatar
the battery is fine.
tennisfan16 is offline   Reply With Quote
Old 12-22-2006, 10:28 PM   #20 (permalink)
caveman74's Avatar
Kevin
I was the first to place the Denso under the headlight.. Hahahha
caveman74 is offline   Reply With Quote
Dumb Laws C2i0v0i1c Water Cooler 58 10-03-2008 09:27 AM
HID Xenon Headlight Conversion Kits CorSport CorSport 77 09-11-2008 02:06 PM
plug and play HIDs edciv Lighting, H.I.D.'s, & Neon 16 12-12-2006 07:22 PM
help: HID Plug & Play question Pukuyo Lighting, H.I.D.'s, & Neon 3 06-24-2006 03:12 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 12:14 AM
