change daytime?(dont know what called) HID?
hi my question is you know civic has daytime light? that turn on when you driving till you turn on the headlight
can you change that to HID?? bcuz i dont like that yellow looking does lots of ppl change that light too? or not worth it?? what is it called? like headlight is 9006? |
Ryan "That CMC Guy"
![]() Join Date: Jan 2011
Ryan
I believe you can but I don't think your DRL (Daytime Running Light) will work anymore. Cause its just a bulb that dims to give it that yellow effect... I may be wrong though... Maybe someone else can confirm this for u
*Fiji FG2*
HIDs wont run at that low of a wattage like it would with bulbs.
yes you can change them to HIDs. no they will not turn on as a DRL but they will turn on as Highbeams and you will get a DRL light warning in your cluster until you turn on your headlights |
#15 (permalink) |
OP, just change your DRL to a yellow bulb. most cops won't care much of it unless they're completely anal about their job.
DO NOT use high beams during fog. light reflects off the particles which reduces the effectiveness of light. you'd be better off getting FOG LIGHTS (3000 kelvin will give you the optimum output - most usable light) for driving in FOG, hence, the name. DO NOT drive using high beams at night unless you're on a deserted road. high beams cause excessive glare and can get you a ticket if a cop spots you driving with them on in the city. it's a danger to other drivers driving the opposite direction. |
#18 (permalink) |
Adam
wow this thread makes me
![]() ![]() ![]() ![]() ![]() Your Highbeam/DRL is a 9005 bulb. Yes you can put HID in it. But you would need to pull the DRL fuse #37 unless you want to look at the DRL warning light on your dashboard. The reason the stock bulb has a dull yellow look to it is because the DRL's run at a lower wattage. If you get a hyperwhite/blue bulb it'd do the same thing just a very slight color difference. Me personally I bought Luminics JDM yellow bulbs and my DRL is a very deep noticeable yellow not the dull ugly stock color. here are my Luminics JDM yellow drl's/high beam... and also a couple when i had yellow low beams.... which i no longer have the police didn't like that idea.... Everything Off drl on High Beams on when i still had yellow low beams now yellow high beam with a blueish low beam |
#19 (permalink) |
brandon (white boy)
high beams in the fogg.....hahahaha your an idiot dude thats the worst thing to do why do you think fog lights are so low on your front end so the fog (water particles in air) dont reflect hight beam light into your face you moron its stupid drivers like you that make driving in bad weather so dangerous for every one else if you wanna blind your self cool hit a tree for all i care get knowledgeable before you try and give out your "professional" idiotic opinion
| HID + Daytime | hiulee20 | Lighting, H.I.D.'s, & Neon | 4 | 01-07-2009 12:36 AM |
| Fogs and daytime??? | vinceiscoo | Lighting, H.I.D.'s, & Neon | 2 | 12-10-2008 01:31 AM |
| might call this rice but i dont care..leds for daytime running lights | GETxERxDONE | Lighting, H.I.D.'s, & Neon | 14 | 10-09-2006 07:03 AM |
| Better pics (daytime) of my EX | aznchzexr | Garage | 5 | 11-23-2005 07:59 PM |
| Better pics (daytime) of my EX | aznchzexr | Garage | 5 | 11-13-2005 09:19 PM |
