Old 11-29-2006, 10:21 PM   #1 (permalink)
Garrison's Avatar
Garrison
Aftermarket Fogs with Oem Harness in a Sedan
ok guys let me make sure I explain this right. First I have a 4 door sedan.
I bought a k2 motors fog kit. I decided I wanted an oem harness in the car. So I bought the oem harness, oem relay, and oem switch.
1) I have it grounded.
2) I hooked up the relay
3) Also the blue connector to the fuse box.
4) I hooked the white/red and the blue/red connectors to the white fuse box cable.
The only thing is not hooked up is a voilet wire. Now in the college hills honda pdf file has the 2 door coupe has a voliet cable. In the 4 door it does not. Has anyone done this in a sedan. In the two door instructions it plugs into a relay by the hood lever. I looked at all the cable colors and they don't match.
So any ideas????
Garrison is offline
Old 11-30-2006, 05:39 PM   #2 (permalink)
Garrison's Avatar
Garrison
Ok I have figured this out. This is very important if anyone who went aftermarket wants to go oem inside.
Coupe Oem Harness
1) 08V31-SVA-10030
Sedan OEM Harness
1) 08V31-SNA-10030
2) 08V31-SNA-10031
3) 08V31-SNA-10032
You will also need a relay and a switch or stalk. Stalk is where it comes on with the column that headlights use. The Switch that is on the dash has a proprietary connector .
1) Dash Switch for coupe or sedan 08V31-SVA-1M035
2) Relay for coupe or sedan 39794-SDA-A05
3) Stalk - 35255-SNA-M01
Garrison is offline
Old 11-30-2006, 07:53 PM   #3 (permalink)
Thanks for the info!
Izzy Sparks is offline
Old 11-30-2006, 09:35 PM   #4 (permalink)
thanks a lot garrison!!
I'm planning to do the same thing you're doing, but i don't really want to install myself. Thanks for the info though!!
jasongg06 is offline
Old 11-30-2006, 09:41 PM   #5 (permalink)
adamhoud's Avatar
Adam
Can you use the stalk on an 06?
adamhoud is offline
Old 11-30-2006, 09:50 PM   #6 (permalink)
Garrison's Avatar
Garrison
I would confirm with the parts guys, but the 06 sedans can I don't know about the coupes.
Garrison is offline
Old 12-01-2006, 01:06 AM   #7 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
If wiring is same as 07, then it will work. Who wants to test it?
fa1 is offline
Old 12-01-2006, 11:37 AM   #8 (permalink)
Garrison's Avatar
Garrison
The stalk is $47 from hondapartsdeals
Garrison is offline
Old 03-27-2008, 02:02 AM   #9 (permalink)
jackolee's Avatar
nice. i needed the switch number
jackolee is offline
OEM harness on k2motors fog lights reelbigfish241 Do It Yourself Articles 44 07-19-2008 12:37 PM
OEM Fogs, I want the fogs to turn on with parking lights Hotwheels Do It Yourself Articles 32 02-23-2007 08:29 AM
Sedan EX: OEM 6CD HU, AUX-IN & LINE-OUT, cannot be too much to ask ? Theodor Do It Yourself Articles 1 09-27-2006 05:37 PM
