My Civics HID DIY Installation - Page 80 - 8th Generation Honda Civic Forum
LinkBack (7) Thread Tools Display Modes
Old 12-17-2009, 01:24 PM   #1581 (permalink)
Scrodums
Unless you can use your high beams for an extended amount of time, then HIDs wouldn't be a useful replacement to your actual high beams. You would be turning them on and off too much, shortening the life of the equipment. However, if you travel excessively on back ROADS with no lights and don't have oncoming cars for a long period of time, then high beams might be worth it.
Just be sure not to confuse bright with light output - these terms are not interchangeable. You can throw on a 30,000K HID kit onto your high beams and be spotted from miles away. The trade off you're making in that option is not having any usable light actually being dispersed.
Old 12-17-2009, 10:06 PM   #1582 (permalink)
phil
sooo hid high beams are a no go? i drive a lot on backroads but there are cars every so often and i would be turning them on and off somewhat...how does that shorten the life of the equipment? also the ddm tuning hids have a lifetime warrenty
akronmusician413 is offline   Reply With Quote
Old 12-20-2009, 12:02 PM   #1583 (permalink)
Scrodums
The toughest phase for ballasts is the start-up period because it is drawing more amps than it does while running. Based on this, turning on and off your ballasts repeatedly will greatly reduce the life the ballast. One advantage of a Bi-Xenon setup is the ability to not to turn on and off the ballasts. The setup uses a solenoid to raise a shield on the projector to expose more light, creating a high beam effect.
Old 12-25-2009, 02:40 PM   #1584 (permalink)
Chris
I tried putting a Set of 8k HID HIGH BEAM bulbs in my 09 SI Sedan and disabled my DRL by pullin fuse 37 and we done the whole plug and play set up for the high beams and they wouldnt work is there anything special i need cause we was using the same manufacture as the low beams and they worked fine with the plug and play. We even tried a relay. So i had to settle for low and fog light HIDs. Somebody please give me some info on what i need to do to get my High beams in HID
BlueSI64 is offline   Reply With Quote
Old 12-25-2009, 09:00 PM   #1585 (permalink)
Orient Express's Avatar
Here is all the info you need: Don't do it. The high beam reflectors are not designed for HID bulbs. That goes for the fog lamp reflectors as well.
Orient Express is offline   Reply With Quote
Old 12-26-2009, 06:35 PM   #1586 (permalink)
Excuse my noobness, but after you install the HIDs, do you have to adjust it or anything?
SlightInterest is offline   Reply With Quote
Old 12-27-2009, 06:34 PM   #1587 (permalink)
If your low beams were properly adjusted, then No, you do not have to adjust anything.
Old 12-28-2009, 02:13 AM   #1588 (permalink)
Ok thanks! Got my HIDs installed and they look normal...
Old 01-02-2010, 05:11 AM   #1589 (permalink)
ns writeup sir
rocqqa is offline   Reply With Quote
Old 01-06-2010, 06:03 PM   #1590 (permalink)
Maxw's Avatar
Max W
Great write up. I was really looking into getting HID's couldnt find a good write up until now. Thanks.
Maxw is offline   Reply With Quote
Old 01-30-2010, 06:29 AM   #1591 (permalink)
curtis265's Avatar
Bump old thread. Sorry guys, i cbb reading all these responses.
I bought a kaixen PnP kit, and contrary to the advice given by the OP (grounding the ballast), we're given foam tape to ensure the ballast doesn't come into contact with the chassis, i think to prevent it from discharging itself.
I was going to squish up a sponge and stick it in between, but i'm concerend that
a) the sponge might melt if the ballast gets too hot
b) the ballast might spark causing the sponge to melt or even catch fire.
Any recommendations? I'm trying to find spognge tape arund the house, i KNOW it's aroudn somewhere, but can't find it
any suggestions for now?
or should i be making the ballast touch the chassis :S
curtis265 is offline   Reply With Quote
Old 01-30-2010, 07:23 AM   #1592 (permalink)
I didn't ground my ballasts. Do you have to? What happens if you don't?
SSmokin99 is offline   Reply With Quote
Old 01-30-2010, 12:56 PM   #1593 (permalink)
Grounding Ballasts
By not grounding the ballasts cases by fastening them to the chassis with a screw or bolt, you run the risk of setting up a floating ground loop which will show up on the radio as a whining noise.
But the main reason is that using two-sided tape, or zip-ties, will guarantee that the ballast will come loose at some point. Do it right the first time and then forget it.
Old 03-17-2010, 05:47 AM   #1594 (permalink)
8th-a-holic
ArmyofOne's Avatar
Josh
mine are on their way now. thanks man!
ArmyofOne is offline   Reply With Quote
Old 04-14-2010, 03:07 PM   #1595 (permalink)
Question Questions regarding 2010 ???
Originally Posted by jdover52 View Post
Thanks for the write-up OE, very helpful and informative. I just installed a 4500k pnp hid kit from ddmtuning yesterday and have been trying to aim them better to reduce glare. Quick question though, are those your real cutoffs or did you modify them? Because if you zoom in on the picture and turn up the brightness, there seems to be spray-paint on the wall right above your cutoffs...
would you all agree this picture is pretty good for a reflector and not a projector? also, would a 2010 HID be better than say a 2008? in the housing it looks like there is a tiny projector that sits at the tip of the bulb? is that what it is? is anyone doing projectors with newer civics or are the PNP pretty good ?
elykoj is offline   Reply With Quote
Old 04-26-2010, 09:17 PM   #1596 (permalink)
bigeasy's Avatar
Erik
Exclamation 35w Vs 50w
Hi, in my 2006 civic 2dr. should i go with:
35W 6000K HID Conversion Kit with 9006/HB4 Xenon light bulbs
or
50W 6000K High Watt HID Conversion Kit with 9006 Xenon light bulbs
and does anyone know of a good/Trustworthy site/seller of either of those bulbs + 06Honda Civic 2Dr dual Halo LED Projector Headlights - Black only
Please post/pm/e-mail me if anyone knows!
Thanks!
bigeasy is offline   Reply With Quote
Old 04-28-2010, 08:59 PM   #1597 (permalink)
bigeasy's Avatar
Erik
guess no one looks here anymore :P
I found some tight assemblies + KITs though. I'll see how they work out once i get em!
Old 06-18-2010, 01:19 PM   #1598 (permalink)
YIJIA
nice post, just installed mine, btw, how to adjust light beam highter, it seems too low and narrow angle
sneakers is offline   Reply With Quote
Old 06-23-2010, 10:46 AM   #1599 (permalink)
After 2 years of solid service from this kit, my right side ballast/bulb failed.
CampusLegendAR7 is offline   Reply With Quote
Old 07-18-2010, 02:54 PM   #1600 (permalink)
tda1337's Avatar
Rick
I would not buy this kit. I decided to buy one for the fogs i have, HORRIBLE!
they flicker badly, checked the relays i was running, not the problem
DDM kits are MUCH higher quality. and much cheaper
these things SUCK
PS DDM slim ballasts put out less power tho, so they are not as bright
ALSO
IF YOU ARE RUNNING A SOUND SYSTEM< USE THE RELAY HARNESS!
a while ago i said why bother, and now i have the reason. luckily caught it early.
with over 1300RMS powering my speakers and sub/s
the voltage would drop, but the HIDs wouldnt dim. i thought AWESOME
NOT AWESOME. burnt connector on the stock harness!!!
heed my warning, unless you have a bone stock electrical system, run the harness
tda1337 is offline   Reply With Quote
Instalação de xenon no farol baixo This thread Refback 09-14-2011 05:01 AM
HID: How much on an 8th gen??? This thread Refback 09-10-2011 03:07 AM
07' SI, HID install Q's... - HondaCivicForum.com This thread Refback 09-02-2011 06:02 PM
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 01:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 09:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 02:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 03:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 100 11-11-2010 01:49 PM
hid installation help. StyleZ California South 14 10-22-2008 08:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-06-2007 12:36 AM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 05:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 01:14 AM
